is it safe if i tap into the downpipe for my pyro or should it be done in the manifold.
in the MANIFOLD!!
yeah, manifold for sure
mine is in the down pipe and it works good you just have to remember that temps can drop a couple hundred degrees from the manifold.
manifold is definately better but down pipe is alot better than nothing. i plan on putting mine in the manifold if i ever end up taking it off, for now the down pipe works. |
Put it in the manifold and there is no guesswork...
Maniflod all the way. FYI you don't have to take it off.
i'm having an exhaust shop weld basically a nut on the manifold so i can screw the probe into the nut so i can make sure it will be tight
you dont have to weld a nut... just drill and tap the hole.... this is the way everyone does it and i have never heard of any problem ...
dont let them convince you that you need a nut welded... |
I wasn't sure if the manifold was strong enough to keep a probe from rattling out
Yeah mine is drilled and tapped and there is no way it is going to move. Manifold for sure.
