moving my trans cooler? - Ford Powerstroke Diesel Forum
Old 09-19-2008, 09:13 AM
Well i have been thinking of trying to keep my trans temps even lower.... currently they dont get hotter than 180 on a very hot day....
i run the 6.0L trans cooler and a secondary cooler with a fan in front of the Rad.
i have been thinking of taking off the secondary unit and trying to see how i can move the 6.0L from the stock location to in front of the rad.... and i would add 2 fans to it to push the air through it even faster... i dont want to starve the rad. of cool air...
what do you guys think? possible?
hoping to get some tech responses
truck is a 03 7.3L
-Raul
Old 09-19-2008, 09:28 AM
What u talkin bout willis
Send a message via AIM to REDPOWERSMOKER Send a message via Yahoo to REDPOWERSMOKER
I WOULD THINK THAT WOULD WORK
Old 09-19-2008, 10:13 AM
yah i think its possible... but just wondering if their is a certain reason why it wouldnt work....
Old 09-19-2008, 10:19 AM
Ole White
I don't see any reason why you can't do this it should work great
Old 09-19-2008, 10:28 AM
I have seen set ups where the a/c cond. and inner cooler are switched, but my question is how is yours set up, because i just changed my trans cooler and it was infront of everyhing, expect half was covered by a/c
Old 09-19-2008, 10:36 AM
BRS BRS is offline
Raul, I was digging through old posts and saw your post about the Derale cooler mounted right behind the grill. I was actually thinking about doing this too since I'm in som much stop and go traffic all the time. So even with the 6.0 cooler and the fan driven Derale, you still hit the 180's?
Ben
Old 09-19-2008, 11:20 AM
Ben
well i dont turn on the fan ... but i also think that since its mounted in front its not letting as much air pass through the Rad and the 6.0l cooler... thats why i want to take it off or relocate it somewhere else and see if that makes a diff...
i see 180 when its over 100 degrees outside and im in stop and go traffic...
Old 09-19-2008, 11:41 AM
BRS BRS is offline
OK, that makes sense, thanks!
Ben
Old 09-19-2008, 02:33 PM
bumping this up for a tech
Old 09-19-2008, 09:28 PM
I would get rid of the secondary cooler. I bet that adds too much restriction to the cooling. With my 6.0 cooler the hottest it got in 111 degree weather was 160. That was going about 75-80 mph unloaded. That additional cooler may make your tranny hotter??? I know BTS doesn't recommend adding any more coolers inline with the 6.0.
I wouldn't think moving the cooler will gain much. I don't think the underhood temps are that much hotter when cruising down the highway at 65-70 mph...
The fans would be great for stop and go traffic in town with low speeds but on the highway it may restrict the airflow through the cooler...?? I don't know some of those fans have some large shrouds that cover alot of area that may restrict some airflow...
Most the time it is hard to get my tranny hotter than 140 degrees. Even when I go drag racing it doesn't get that hot.
