More ? TW - Ford Powerstroke Diesel Forum
Old 09-19-2008, 05:33 AM
More ? TW
I watched Maintains video DP install. Is the TW chip the same procedure? Also I have read some threads that talk about PCM codes. On the Total Diesel Performance site There is no spot to put in PCM code. My question is do I need it and where do i find it on the pcm or is there another place it might be. I am asking because i would like to eliminate any for seen problems. I read thread Worth the wait which brougt me to this concern.
Old 09-19-2008, 06:08 AM
yes you install it the same way. I don't think you need to worry about the pcm code
Old 09-19-2008, 06:43 AM
a truck
If you want a full write up on how to install the TW chip I have one I wrote up with pictures and everything if you want it just send me your email
Old 09-19-2008, 06:49 AM
Almostdunfukinwidit
Exact same process as the DP chip. And you do need to know your PCM code. Its on a sticker on the PCM
Old 09-19-2008, 07:00 AM
Where on the PCM, do I haveto remove it to see it? I looked and did not see it can I just remove the plastic cover wthout removing the plug in the engine compartment? To read the code. I can use a mirror to see it if it is on the PCM box somewhere. OR just pull it out.
THANK YOU!!!!!
Old 09-19-2008, 07:06 AM
Almostdunfukinwidit
Here you go
click here for instructions on locating your PCM code
Old 09-19-2008, 07:22 AM
THANKS GUYS!!!!!
Sorry for all the questions I just want everything to be right the first time. And gather as much info that i can so when problems arise. I am prepared. Thanks again.
Old 09-19-2008, 09:14 AM
it will be easier if you get the PCM code... write it down in the box provided under what mods do you have....
that way we dont have to guess at what PCM code you have
-Raul
Old 09-19-2008, 03:14 PM
You can also find it on Tony's website:
http://www.totaldieselperformance.co...les.asp?id=133
