AutoMeter Gauge for Trans...just plug and play - Ford Powerstroke Diesel Forum
Old 09-16-2008, 03:32 PM
7.3L pullin a 7.0L S/C
My trans gauge is here and has these 2 fitting and a probe to go in one of them....
I read somewhere I thought there is a port on the transmission where this just screws in...true?
What side and where?
Old 09-16-2008, 04:33 PM
Drivers side, just infront of the shift linkage...
Old 09-16-2008, 04:56 PM
Send a message via AIM to jhaddox
you dont use either of those adapters that are above the long peice. you take out a small nut on the drivers side right where that picture is. its just a small bolt. take it out put in the themo and then run a wire off of the thremo to the guage. it should ground itself from the tranny
Old 09-16-2008, 06:11 PM
Thank you.
Old 09-16-2008, 10:25 PM
is it better to put it in the hole you guys show or in the trans pan? i have a mag-hytec pan i havent gotten around to putting on yet and am waiting on my gauges im not sure which place is better for the sending unit
Old 09-16-2008, 10:27 PM
put it in the test port (sorry didnt want to say put it in the whole lol)
it will be perfectly fine their...
-Raul
Old 09-16-2008, 10:34 PM
so it is better to do it there then the pan? what about that wire thats on the bolt you take out?
Old 09-16-2008, 10:35 PM
the wire from the bolt is your trans temp wire... the pic shows the probe alread installed
Old 09-16-2008, 10:39 PM
ok, thanks alot raul
Old 09-17-2008, 08:03 AM
I had my transmission filter changed and they installed it for me...just need to hook up the gauge now.
