i did the 2''daystar leveling kit and 285/75/17 plus wheels. I took it to get aligned,,,,,, they got it close, but i need to change the caster/camber bushing???? where can i find them and are they hard to change? the shop said i need single adj.ones at least 2.5 degrees....Thanks TURBOTRuck
If you took it to an alignment shop they should have had the bushings. our alignment shop installs that when we do the alignment.
The shop did not have the bushings in stock, how hard are they to R&R?
try your local NAPA store that were i found mine good luck
You have to take the upper balljoint nut off and use a airhammer to push the bushing out. But the only problem is you dont know what position to put the bushing in without having an alignment machine.You have a certain degree that you have to put the bushing in to get the proper alignment angle.
and to put them back rubber hammer? or will it push in????? thanks
