Edge with DP - Ford Powerstroke Diesel Forum
post #1 of 5 Old 09-15-2008, 12:10 PM Thread Starter
haymaker02's Avatar
Question Edge with DP
We've got an '02 that has an edge juice with attitude and it s a dog. I was wondering if it would be possible to put a Dp tuner on it and keep the edge on there just for the gauges. I was thinking we could keep the edge set on zero(stock) and use the DP for the power. I've read on here that you don't want to stack chips on powerstrokes but if this would work we wouldn't have to invest in a new set of gauges. Let me know what you guys think. I would appreciate it!
'01 Stroke
F-350 SC LB
Silver w/barbwire and tinted windows
Black tool box
Leveling kit
Straight pipe
285 Toyo mt's
Autometer guages: pyro, tranny temp, boost on the pillar
Dp tuner, stock, high idle, 60 tow, 80 econ, 120 smile inducer
UMP intake
ITP boost fooler
Wicked wheel
Clear marker lights
Soon to come:
JW valvebody
4" exhaust
haymaker02 is offline
post #2 of 5 Old 09-15-2008, 01:02 PM
SeeYa's Avatar
Absolutely. We have several customers that do this.
Diane
Custom Tuning-Computer Chips
Flash Programmers-Aftermarket parts
Ford Power Stroke Engine and Transmission Tuning Specialist since 2004.
828-221-0076
SeeYa is offline
post #3 of 5 Old 09-15-2008, 01:06 PM
RadarRider's Avatar
The only problem is: with the DP Tuner, you'll need an ITP Overboost Annihilator or some other sort of boost fooler to prevent defueling. With the ITP Ovrbst Ann, the Edge Juice w/ Attitude will only read 17psi on your boost readout, because it reads off the MAP sensor. You'll be pushing much more than that with the DP. Your best bet is to get your hands on some mechanical gauges.
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #4 of 5 Old 09-15-2008, 01:07 PM
RadarRider's Avatar
This isn't the same rig from your sig, right?
post #5 of 5 Old 09-15-2008, 01:59 PM
SeeYa's Avatar
Analog gauges will give true readings, definately. EGT's being the most important. If he has a probe for EGT's then I would say he's fine. With Jody's new codes tunes he won't need to do an OB kit. Jody takes care of the defueling also.
List of tunes
828-221-0076
SeeYa is offline
