how do traction bars work? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 Old 12-25-2013, 01:12 PM Thread Starter
7.3LDriver's Avatar
Quoted: 5 Post(s)
how do traction bars work? and do they really make a big difference?
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #2 of 14 Old 12-25-2013, 02:43 PM
schlutzer's Avatar
Quoted: 18 Post(s)
They prevent your pinion angle from changing, axle wrap it's called.
They make a huge difference.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #3 of 14 Old 12-25-2013, 04:51 PM
Joel's Avatar
Quoted: 10 Post(s)
They transfer weight to the rear tires. They do work great. Do you really need them though? They become more necessary when more power is added. Like a lot more...
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 14 Old 12-26-2013, 06:35 AM
Quoted: 144 Post(s)
Feedback Score: 3 reviews
Yea, you do it in response to a problem (or you're a poser )
If you found your trucks suspension couldn't put the "bite" of the Tire/HP combination to the ground without causing the Leaf Springs trying to wind-up and causing Huge issues, then maybe...
For most it's like a Wing though
NoRalPh is offline
post #5 of 14 Old 12-26-2013, 06:37 AM
atvrider93's Avatar
Quoted: 8 Post(s)
My truck needs then and I'm hoping my old girl still has 200hp in her.
sent from me
1996 F350 4x4 CCLB-- I'll miss her
1996 F350 4X4 RCLB zf5 213K
6637
OBA w/horn
DE 5"
PHP tunes
Mud Country 315/75/16
2008 Wr250X
Originally Posted by belz View Post
There u go Tom. John may not be sexy, but he can tutor you, lol.
atvrider93 is offline
post #6 of 14 Old 12-26-2013, 08:33 AM
layson's Avatar
Quoted: 82 Post(s)
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #7 of 14 Old 12-26-2013, 08:39 AM
Joel's Avatar
Quoted: 10 Post(s)
Good video
Joel is offline
post #8 of 14 Old 12-26-2013, 08:41 AM
layson's Avatar
Quoted: 82 Post(s)
Quote of the Day:
layson is offline
post #9 of 14 Old 12-26-2013, 11:50 AM
schlutzer's Avatar
Quoted: 18 Post(s)
Yeah it's certainly not a "poser" thing the all spring lift vs traction block video shows that. Even if you aren't getting hop, anything over a 35" tire and 4" lift you ARE getting axle wrap, and you ARE putting extra unneeded stress on your springs.
IMO, the best system is an all spring lift, with a proper traction bar setup, you get a nice stable ride, no wrap, and everything just works nice and smooth. To me, seeing a thought out, no block system is much more impressive than big blocks and big traction bars.
post #10 of 14 Old 12-26-2013, 12:05 PM
I have a spring lift out back with traction bars. The traction bars made a BIG difference. However, if I had to do it again, I'd keep the factory springs (better ride, better articulation) and use a one piece, 6" block that has the ladder bar mounts.
A traction bar has 2 mounting points, a ladder bar has 3.
Karl and his 2003 Souper Doody
Karl and his 2003 6.0
Barefoot Accelerator Pedal
TRICO Force wiper blades
Yellow Military Aircraft Valve Stem Caps
Offensive "Stick Family" Decal
Big Ol'Honkin 1 1/4" Shank Receiver Hitch
WHAT!?! I was trying to list stuff that everyone else
hasn't already listed for their truck!
Karls03 is offline
