BD chip install help
Ok guys, i have had my BD chip in now for a while, thanks again Dave, but i never cut a hole in my pcm cover. Dave said he did, but what i can't figure out is how did you guys cut holes for these chips? They are so big that you really need to cut off on of the screw tabs and i don't want to do that. I had a hard time getting the pcm re-installed the first time so i wanted to cut a hole now, but its not gonna be big enough without taking out a mounting bracket. Any ideas?
I cut a hole in the black cover that covers the pcm. The chip can go in and come out with no issues.
You have tony's tunes though. I think their chip is small. The part that actually plugs into the pcm. These dang BD chips are HUGE. I would have to cut 3/4 of the back off the black cover. Thats what i want to know, is there another way around that. If not oh well, it fit before. I just have to remove the pcm everytime i want to take out the chip.
Yea i only had to cut a hole about the size of the bottom of a pack of cigs. I feel sorry for you cause pulling that f@#ing computer sucks. Just think you'll be a whiz at it after a few more times....lol
yeah it does suck having to take it out, but i have no real reason to take it in and out all the time. I just didn't want to break the chip or the pcm by putting too much pressure on it from forcing it back into the firewall brackets.
I can only offer my experience with my evo.........it was snowing and i had it on extreme going down 694. The barely touch the gas and im starting to go sideways at 60mph. Luckily with the evo i was able to just pull over and go back to stock for the day. Now with the little flippy chippy i can do it on the fly. So that would probably be the only reason to take it out. Just my .02
Thanks for the help anyway. I got it back in the truck. Its just a little snug. Someday when i can afford custom tunes, it won't be an issue except for the gaping hole in the pcm cover. Are you gonna make it next sat?
Dont know yet im going to put in new batteries on wednesday and see if i can get her to start. If im running i will be there for sure |
are you having trouble getting it started?
yea i replaced the hpop gasket on the timing cover and have air in the lines, so i gotta crank it for awhile. but my batteries are weak and die after about 20 seconds.
