What size injectors with Brute 66 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 Old 12-23-2013, 09:58 AM Thread Starter
r_marczak_83's Avatar
I am considering after the 1st of the year getting a Brute 66 turbo and injectors. I am looking for around 500-550 hp with stock 17* HPOP. I want to be street friendly also as this at the time will be my DD.
What size should I go with?
E99 F250 ex-cab 7.3
Barder 66mm/1.15 a/r turbo, EBPV delete, 4" turbo back w/ 6" SS tip, Full Force 160/100's, 17* HPOP, 140v IDM, Rebuilt 4R100, DP-Tuner, boost fooler, aFe Pro Dry S filter,CCV Mod, HID's, 20" Fuel Hostage w/ 33" Nito MT's
r_marczak_83 is offline
post #2 of 12 Old 12-23-2013, 10:04 AM
CSIPSD's Avatar
Change tuners and get the Hydra, then go with some P.I.S 230/100's and No Limit tuning...
Should get you really close to that number add a Honey Badger to that and you should get there without issue.
No Limit Tuning & Design
Ford710 likes this.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 12 Old 12-23-2013, 02:21 PM Thread Starter
How is this setup for pulling also (dual axle trailer with full size truck)?
E99 F250 ex-cab 7.3
post #4 of 12 Old 12-23-2013, 03:24 PM
CSIPSD's Avatar
https://www.youtube.com/watch?v=f0KFTpVxBTU
For some reason Youtube does not embed here which is weird...
No EGT issues with the set up in my sig.
Joe
CSIPSD is offline
post #5 of 12 Old 12-23-2013, 06:21 PM Thread Starter
Nice.
What kind of load did you have behind it?
E99 F250 ex-cab 7.3
post #6 of 12 Old 12-24-2013, 02:38 AM
heisman01's Avatar
Quoted: 54 Post(s)
Is your trans still stock?
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #7 of 12 Old 12-24-2013, 04:03 AM
Thuglike's Avatar
As Joe mentioned earlier....238/100's are a real nice mate for the brute!!!!!
It would be a real nice, clean, crisp 500 with plenty of towing capabilities.
Thuglike is offline
post #8 of 12 Old 12-24-2013, 07:13 AM Thread Starter
Its had a rebuild 2.5 years ago.
E99 F250 ex-cab 7.3
post #9 of 12 Old 12-24-2013, 07:13 AM Thread Starter
That's what I'm talking about!!
E99 F250 ex-cab 7.3
post #10 of 12 Old 12-24-2013, 08:20 AM
CSIPSD's Avatar
Another video with the same set up pulling my 10k RV... Different tuner but...
Joe
CSIPSD is offline
