installing pyro probe.... - Ford Powerstroke Diesel Forum
post #1 of 9 Old 09-12-2008, 11:35 AM Thread Starter
well ive gone to a few local shops around my area to try and get my exhaust manifold drilled and tapped for the probe but no one wants to try. Ive seen in the instruction that it can be done mounted on the truck but im not sure. Also does it matter what side its mounted on?
Ive been thinkin of doing it myself now but im pretty sure i need a special drill bit for cast iron. Ive never worked with cast iron before and dont want to ruin the manifold.
any help is appreciated.
stang_1973 is offline
post #2 of 9 Old 09-12-2008, 11:47 AM Thread Starter
nevermind i just found a thread on this topic,,,,
but what kind of bit do i need to use?
post #3 of 9 Old 09-12-2008, 06:10 PM
Just did mine a week ago.
I started with a small bit and worked up to the "R" size bit that the instructions called for. Just used a regular drill bits from a big set I got at Harbor Freight. I don't remember the exact sizes I used to but I used 4 smaller ones before I got to the R size.
2002 F-250 Crew Cab
TYMAR DIY Intake
Walker BTM
ISSPRO Guages(Pyro,Boost,Tranny)
cparks72 is offline
post #4 of 9 Old 09-12-2008, 07:10 PM
dubl_t's Avatar
Stang, I think you're thinking of stainless, cast iron is weak and porrous.
mods thus far:
1704 tuner gizmo, BHAF, 4" DP to 5" stack, FPR w.109 shim, disconnected wastegate, plethora of gauges, 10k mod w/ 20k resistor (removed after it jacked up my connector), 17*HPOP (not really), hybrid sticks (I wish), some kinda badass turbo (another lie), mega body damage (that's gospel).
dubl_t is offline
post #5 of 9 Old 09-12-2008, 09:51 PM
Berm Buster
Speedyboy487's Avatar
Any bit should do. You might be able to find a chart online showing what size bit to use to get the proper size hole for the tap.
2002 F-250 7.3L 4x4,6 Speed,Hyperpac, MBRP 4”dp5” K&N/DIY Intake, Foil Delete, Rough Country leveling kit, 305/70/16 Dunlop Mud Rover
Autometer Ultra Lite ll Pyro Boost- TW tunes
Speedyboy487 is offline
post #6 of 9 Old 09-14-2008, 04:58 AM Thread Starter
ahhhh! ok, cool guys , thanks.... last gauge to get done.. sweet.
post #7 of 9 Old 09-14-2008, 03:00 PM
Powerstroke Junkie
NCHornet's Avatar
I haven't heard of anyone cracking a manifold by installing a pyro probe. I stepped up in bits and dipped them in grease. You can also use the clamp on probe and then all you need is a hole and no tap. Just another option.
NCH
NCH
Proud Father of USAF Airman
2000 F350 DRW,CC,LB, 4X4, Western Hauler Pkg.
Ford AIS/ BTM, FTVB
My CCV MOD, Coolant filter
06 Grill, 05 lights,6.0 trans cooler
Cyro/Hawks, JVC Touchscreen HU, JL C5's, Infinity 800watt amp,
DP tunes, 60 tow/80 e/120 race, on a SCT2 tuner
P3 controller, Brite Box Turbo Lifesaver
KMC Wheels x 4
Friends Don't Let Friends Drive Trucks With Generic Tunes
NCHornet is offline
post #8 of 9 Old 09-14-2008, 03:40 PM
eschaner's Avatar
Yeah very simple. Just be careful when you tighten the probe in not to strip out the hole. And use nickel anti-seize(good up to 2000 degrees)
Eric
2002 F-250 SD 4x4:burnout
afe stage 2 air intake
4" dual exhaust w/ delete Y pipe
2" leveling kit
ats turbo housing w/ x-wheel
Tony Wildman chip
Firestone destination m/t's
Ultra 175 Rogue wheels
tri-pod w/fuel pres, ex.temp, boost
Zoodad mod.
Foil delete
Rhino lining
eschaner is offline
post #9 of 9 Old 09-14-2008, 03:42 PM
Other vehicle is an F250
Hank's Avatar
Chuck (Chuck) did mine for me. PM him. He'll be able to answer all of your questions.
2001 F250 Lariat Crewcab, Automatic, 4X4
(Late '99 Regular Cab Work Truck)
6.5" Pro Comp Lift ~ Traction Bars ~ Son-Built Sliders ~ 16" Pro Comp Xtreme Wheels with 35" BFG TA KM2s
4" Banks Exh.-Power Elbow ~ Wicked Wheel ~ DIY AMSOIL EaAU4090 Intake ~ PHP 6 Pos Chip ~ LowDown LED Upgrade
Stage 1 Injectors ~ HankDaddy
Mod. ~ BUILT TRANNY! 352 HP Shootin' for 375!
CAROLINA POWERSTROKE ASSOCIATION
Hank is offline
