Stalls after turbo surge/fart - Ford Powerstroke Diesel Forum
post #1 of 6 Old 12-20-2013, 12:59 AM Thread Starter
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Ok so since my truck has had a programer and a chip if i work the truck hard and have higher rpm and let off my truck i get turbo surge and my truck will stall. This is with between 20 and 25psi of boost. Stock injectors and stock turbo on my E99 f-250. Any ides on why this maybe happening?
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #2 of 6 Old 12-20-2013, 03:47 AM
Shadowfax's Avatar
Quoted: 9 Post(s)
Is it throwing any codes? You have any way to check fuel pressure. If it's not fuel related it might be a sticking ipr. When mine went out the truck would die if I hit the gas then let off quickly.
2015 f350 lariat
2003 Jetta TDI 5spd
Shadowfax is offline
post #3 of 6 Old 12-20-2013, 02:52 PM
blue99stroker's Avatar
Quoted: 247 Post(s)
even though you have a 10 blade compressor wheel you can still get surge.
i could get mine to surge with the gen1 wicked wheel which is the same as whats in your turbo.
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is online now
post #4 of 6 Old 12-23-2013, 04:19 AM Thread Starter
Nope no codes checked with a snap on moddis and fuel pressures were good. It only happens under hard load, like when i hooked to the transfer sled this past summer soon as i let off it surged and died. I was woundering if maybe the surge was starving it for air just enough to stall the engine. im befuzzled
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
post #5 of 6 Old 12-23-2013, 02:44 PM
Quoted: 247 Post(s)
was your truck defueling? ive had that happen before.
trying to climb a steep hill offroad and pedal to the floor, ended up killing the truck lol
post #6 of 6 Old 12-24-2013, 10:54 AM Thread Starter
could be idk figured maybe someone here might know
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
