Fuel system ? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-19-2013, 02:37 PM Thread Starter
heisman01's Avatar
Quoted: 53 Post(s)
Fuel system ?
I was looking into an frx, and obviously that let's any unused fuel flow through the head and back to the return line. (Now for my ? Sorry if newbish still learning fuel systems fully)
I was told about a system that runs fuel to all four corners at the heads, my main question is where does the unused fuel go? And doesn't feeding all corners just increase the amount of air in the lines or possibility of air. Which is supposed to be the benifit of an frx is to let said air escape back to the return line.
Anyone running that style set up or know of an instal thread?
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #2 of 9 Old 12-19-2013, 03:01 PM
CSIPSD's Avatar
I am not a fan of a 4 line feed, except for a full competition system.
What are your plans?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 9 Old 12-19-2013, 03:42 PM Thread Starter
heisman01's Avatar
Quoted: 53 Post(s)
Stuff I want to get list:
175/80 psi's
Riffraff wheel/up pipes
Bts valve body, tq, and trany rebuild.
Just a 350-375 hp reliable cruiser with some towing(sub 10k) and road trips.
post #4 of 9 Old 12-19-2013, 04:06 PM
Quoted: 2 Post(s)
175/80 psi's
I have fuel to all 4 corners I have no issues and I have had injectors out a few times
2000 f-250 superduty
leveled on 375/65/16 MTZ's 16x12 Classic 3,"X" code front leafs, afe stage 2 intake, 175/80 p.i.s injectors, 38R turbo, Adrenaline hpop,ITP return fuel sys with reg,
4" from turbo back, lentech built trans, 12 billet converter, DP tuner!!!
krs1r/t is offline
post #5 of 9 Old 12-19-2013, 04:42 PM Thread Starter
heisman01's Avatar
Quoted: 53 Post(s)
So do the heads and rails/tubing just presurise with fuel and any excess fuel is returned back via the return line?
post #6 of 9 Old 12-19-2013, 04:47 PM
CSIPSD's Avatar
If you have the fuel system shown in your sig then you dont have a 4 line feed, you have a regulated return...
To the OP, I would just install a fuel pressure gauge, do the in tank and pre pump mods and go on with life. Throw the riffraff FRX in there just for good measure if you want.
Keep the fuel pressure at or above 60-65 psi and your good to go.
Joe
CSIPSD is offline
post #7 of 9 Old 12-19-2013, 06:53 PM
Joel's Avatar
Quoted: 10 Post(s)
OP,
The RiffRaff FRx does not supply fuel. It adds return lines to the opposite ends of the heads of the feed lines.
I have it. Just installed it this week. It is a very nice piece and looks well built.
I didn't really notice any difference with it, but I'm happy I got it anyways.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 9 Old 12-20-2013, 03:48 AM
Quoted: 2 Post(s)
You might just be right, I will have to look at the way it is plumbed
krs1r/t is offline
post #9 of 9 Old 12-20-2013, 02:49 PM Thread Starter
heisman01's Avatar
Quoted: 53 Post(s)
Yeah a fuel pressure guage is on my stuff to get list as well, I was thinking for the future on the 4 corner set up but I think the frx will be better for my realistic use. Now getting traction will be my next step since any fuel starvation questions have been answered.
