transmission shifts hard - Ford Powerstroke Diesel Forum
post #1 of 13 Old 12-19-2013, 12:35 PM Thread Starter
A have a 2000 f250 7.3 with 156000 miles. And I have a ts 6 pos. Chip. And my transmission shifts hard when I turn it on 100 or 140 but it shifts good and smooth on 50 and 75. What would make it do that would I just need a valve body or a new transmission.
honda144 is offline
post #2 of 13 Old 12-19-2013, 12:58 PM
Quoted: 27 Post(s)
A valve body would be a good idea to help your tranny last longer and stay healthy.
But technically you really should contact your tuner and talk to them, they can tweak things for each tune so i would call them and talk it out. More than likely they will be able to get you fixed up.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 13 Old 12-19-2013, 01:15 PM
importedaze300's Avatar
Those are supposedly race tunes on the generic you will also notice at idle with the 140 you will idle up but if you still wanna run those tunes I would at least put a shift kit in the shifting will be stiffer but still jerky
6637 filter
5" exhaust
bts valve body
gtp38r
no ebvp pedestal and exhaust outlet
oil feed line cross over
ts 6 position chip
6" lift
20" fuel wheels on 35s
2x4 to 4x4 conversion
2001 supercab 4x4 manual no mods
importedaze300 is offline
post #4 of 13 Old 12-21-2013, 06:22 AM
twildman's Avatar
Quoted: 2 Post(s)
Feedback Score: 3 reviews
Because the line pressure is raised up in the tunes on the higher hp tunes to help the trans to keep from slipping. It can be to much on some trucks. When you say hard shifting is it neck snapping or just real firm?
Custom tuning for your 1994-2010 Powerstroke Diesel
Full line of performance products for all brands of diesels
05 King Ranch with some stuff on it.
twildman is offline
post #5 of 13 Old 12-21-2013, 06:38 AM Thread Starter
Its like neck slapping. It jerks pretty hard.
honda144 is offline
post #6 of 13 Old 12-21-2013, 07:17 AM
twildman's Avatar
Quoted: 2 Post(s)
Sounds like the springs are getting weak in the valve body and bottoming out due to the higher line pressure being called for.
twildman is offline
post #7 of 13 Old 12-21-2013, 07:57 AM
hansel's Avatar
Quoted: 94 Post(s)
You, like me need a valve body. I was having some what I thought was hard shifting before I got my PHP Hydra, and was thinking that the tuning would correct the problem along with the extra HP, but it didn't and Bill spent a few hours trying too tweak the transmission, but in the end I will need too install a JW valve body.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #8 of 13 Old 12-21-2013, 11:53 AM
Jerrybizzle's Avatar
Quoted: 21 Post(s)
Have you had valve body install priced at all? Wondering what it would run to have it installed? The valve bodies aren't that expensive but is install difficult or expensive?
2012 f250CCLB, 35x12.5/17 Kanati mud hogs on race line assault wheels, 2 inch lift
Mini maxx
Jerrybizzle is offline
post #9 of 13 Old 12-21-2013, 11:57 AM
Quoted: 727 Post(s)
Very easy to install. About 1-2hrs depending on how OCD you are about being clean.
BTS has an install PDF download.
Corey@CNCFAB is online now
post #10 of 13 Old 12-29-2013, 02:13 PM Thread Starter
So would y'all guys recommend a john woods valve body?
honda144 is offline
