Transmission temp gauge - Ford Powerstroke Diesel Forum
post #1 of 22 Old 12-18-2013, 05:16 AM Thread Starter
gmat's Avatar
So I'm looking at getting a tranny gauge and am wanting any tips or personal experiences with the different brands of gauges. I want a reliable one but I don't want to break the bank.
I eventually plan on getting the basic gauges(tranny temp, boost and EGT) but I want to start with the transmission gauge first. Also should I go with a 3 slot A-column mount or do one of the 3in1 gauges? What has worked good for y'all in terms of reliability and ease of reading the gauges at night/day?
1999 F350 4x4 Crew Cab Long bed. 240k miles and bone stock as of now. Looking to change that soon
gmat is offline
post #2 of 22 Old 12-18-2013, 08:44 AM
Quoted: 31 Post(s)
I like single gauges in a pillar pod set up. It looks good and is out of the way.
Isspro gauges are one of the best, not my money but I would not go with anything else. There are a lot of other companies that are cheaper but cheaper usually compromises quality.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #3 of 22 Old 12-18-2013, 11:13 AM
03ranger30's Avatar
ISSPROs over anything. I have installed two kits from Diesel Manor (site sponsor) and I love them.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #4 of 22 Old 12-18-2013, 11:51 AM
WHEELER3129's Avatar
Quoted: 92 Post(s)
ISSPROs hands down.
Sent from AutoGuide.com App
2003 F-250 CCSB FX4 7.3L AUTO
PHP Phoenix 6pos.
chip(stock,whisper,25HT,65MT,80DD,120R)
BD Diesel Adj. wastegate
Isspro EV gauges pyro, boost, and trans
Edge Insight CS2
Airaid Intake
Bilsteins
BFG AT KO's 285/75R16
6.0 tranny cooler
4" MBRP straight piped
Bellowed up pipes
WWII
CCV mod
AIH Delete plug
Foil Delete mod
HPx mod
Zoodad mod
Fumoto Valve
Pioneer head unit
Ryan
WHEELER3129 is offline
post #5 of 22 Old 12-18-2013, 01:47 PM
CSIPSD's Avatar
Isspro... You have many choices in pods, A pillar is always a fav but there is the overhead pod and the underdash one. If you want pictures just let me know, I have them all installed.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #6 of 22 Old 12-18-2013, 01:59 PM Thread Starter
gmat's Avatar
I would love pictures of the different options.
gmat is offline
post #7 of 22 Old 12-18-2013, 02:38 PM
CSIPSD's Avatar
A-pillar Quad pod...
Under dash pod...
Overhead...
General...
The quad overhead is available in a triple as well. Quad a-pillar is available in triple or dual...
Joe
CSIPSD is offline
post #8 of 22 Old 12-18-2013, 03:45 PM
Christ Follower
7.3Excursion4x4's Avatar
Quoted: 16 Post(s)
Love all the gauges. Get ISSPRO EV2. Awesome gauges. Especially the one that says you have 46 psi of boost heading into a brick wall.
410,000 miles
PHP Hydra Mishimoto Radiator
Stage 1 Full Force Injectors
MBRP 4" Turbo Back
F-650 Dash w/EV2 Gauges
CT Performance Suspension
Firestone Ride Rite
DieselSite 4R100, Adrenaline HPOP, WW2
DieselSite Engine & Intercooler Boot Kit
DieselSite Tranny & Coolant Filters
SSBC V8 kit with EBC Rotors
NCHornet's CCV, Swamps IDM
Derale Atomic Cool
6.0 Trans Cooler, Cat ELC Coolant
Mag Hytec tranny pan
7.3Excursion4x4 is offline
post #9 of 22 Old 12-18-2013, 03:47 PM Thread Starter
gmat's Avatar
You have the holy grail of monitoring gauges lol. Thanks for the pictures. Was running the wires for the one above the mirror a pain? Because I really like the way that one looked. Also where did you get it from?
Edit: what colors do you recommend for best visibility?
gmat is offline
post #10 of 22 Old 12-18-2013, 03:58 PM
CSIPSD's Avatar
Its called Peak Recall, its avalable (standard) with the Performax line of Isspro gauges. Press a button and all the gauges installed go to there previously recorded Max (minus Fuel pressure and HPO Pressure, they go to min). Press it again and your back to normal. Hold it down for 3 seconds and it clears the ESP (Electronic signal processor)...
Its not hard at all to install the overhead pod, its one of the best IMHO. the wires just tuck in above the headliner. No removing anything other then the A-Pillar which is very easy.
You can get the gauges and pillars from any vendor of your choice. PM me if you want some good ones.
Joe
CSIPSD is offline
