converting to a straight drive shaft? - Ford Powerstroke Diesel Forum
post #1 of 26 Old 12-17-2013, 06:56 PM Thread Starter
SUPERDUALLY350's Avatar
so i found out my center bearing on my drive shaft is going out due to not having enough of a drop bracket. so to put in a new drop bracket and have the bearing pulled and replaced i can have a solid driveshaft made.
SO my question is what are the cons to do this im not running much for mods but a chip,intake,exhaust, would i be better off with a solid drive shaft or just replacing the bearing?
SUPERDUALLY350 is offline
post #2 of 26 Old 12-17-2013, 06:57 PM
Winning DUHHH
Young-SC-Owner's Avatar
Quoted: 8 Post(s)
i have a solid DS, i dont see any CONS to it?
99.5 F-350 SRW Short Bed, Ex Cab.
6637
Wicked Wheel'd,
Southbend
Autometer - Boost, Pyro
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
7 year Veteran with SBFD
Airframe and Powerplant Mechanic
Head Marine Technician
Dont Tread on Me
Young-SC-Owner is offline
post #3 of 26 Old 12-17-2013, 07:00 PM Thread Starter
AWESOME!!! I've just heard **** from people that don't even run them so i figured id see if some one who had one like them
Thanks for your input!
post #4 of 26 Old 12-17-2013, 07:00 PM
CSIPSD's Avatar
I dont see any pro's to it...
For every 1" of lift over 3" add 1/4" of spacer to the center support...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #5 of 26 Old 12-17-2013, 07:09 PM Thread Starter
I see plenty of pros with it.
1 its 150 buck cheaper than having the driveshaft pulled and have and new bearing pressed in and buying an adjustable carrier bracket.
2 you never have to worry about that bearing again.
3 it a straight shot to the rear end. in my eyes its a weak point with the carrier bearing cuz it is a pivot point but thats my opinion.
4 When pull a heavy load when im just taking off or creeping at a light it has a slight bounce and i can see that bearing move when it dose this but it is fine when i haul lighter stuff.
post #6 of 26 Old 12-17-2013, 07:16 PM
ZMANN's Avatar
Quoted: 1463 Post(s)
there is a reason that many shops reportedly won't make them that long IMHO
I like having a center support and I use an adjustable drop carrier bracket that allows for the angle to be adjusted
I have an 8 inch lift for the last 20,000 and for the first 60,000 I had a 6 inch truck just rolled 100,000 miles
still on all the original u joints and carrier
I just bought a carrier bearing from ford for 60 bucks and will replace it for PM
the cost for a 1 piece is a con if the 700 estimate I have seen is true ?
the damage it will do if it gets loose is a con
less parts is a plus
other than that if I had a vibration i couldn't find I might spend the 700 bucks for one
but you won't be alone here are more and more folks giving them a try
EDIT I was typing when u posted can u explain your math of the 1 piece being 150 cheaper? not calling you out just curious
I bought my carrier bearing for 60 bucks and 3 u joints for 80 the pmf drop was 150 IIRC
the one piece was reportedly just over 650 I thought ? I guess you do have resale value in your old DS or maybe a discount from the shop who builds the 1 peice if you find a local shop willing to do this
We Miss you Ronnie
ZMANN is offline
post #7 of 26 Old 12-17-2013, 07:18 PM
Joel's Avatar
Quoted: 10 Post(s)
The reason they don't use a one piece in the first place is that it's not strong or safe enough.
You have to realize that thing is spinning at a tremendous speed and the smallest amount of off balance or alignment can cause it to bend and toss itself out from under the truck.
It has happens numerous time on the dyno when people hotrod 1/2 ton Chevy pick ups.
It's just too long of a shaft.
Really, if it's cheaper (which it is) don't you think the factory would have been happy to use a one piece shaft if it was a good idea?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #8 of 26 Old 12-17-2013, 07:19 PM
Winning DUHHH
Quoted: 8 Post(s)
Just to add, the damage ANY DS will do if it gets loose without a hoop is a CON. So that argument is invalid
6637
Wicked Wheel'd,
Southbend
TW 6 Pos Chip
Water/Meth Inj
Diamond Eye 4" TB
Dont Tread on Me
post #9 of 26 Old 12-17-2013, 07:22 PM
Joel's Avatar
Quoted: 10 Post(s)
Not really.
A 6" wooden dowel is much harder to snap than a 12" wooden dowel.
Joel is offline
post #10 of 26 Old 12-17-2013, 07:27 PM
ZMANN's Avatar
invalid argument it is not plus it's just a discussion ;-)
think about it and both ends the carrier is a drive shaft loop so it is captured in the loop a failure at the other ends will not be as violent IMHO
and i have had a long DS let go it was bad news
if u want to pole vault far do you want a short or long pole LOL
We Miss you Ronnie
ZMANN is offline
