block question - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-14-2013, 06:32 AM Thread Starter
dirtboy33's Avatar
block question
Something happened to my bottom end and my blocks cracked. Still runs but has a miss. I'm gonna rebuild it myself. My question is are all the 7.3 powerstroke blocks the same or do I need a 99-03 block? The specs for my truck are in the sig at the bottom
2002 F-250 7.3L 6 speed, 4" turbo back straight pipe, spectre intake w/ brute force dry filter, XDP compressor wheel, DIY boost fooler, PHP FU, oil HPX, ccv dumped, ebpv delete, unplugged waste gate, zoodad mod, AIH delete, 6.0 intercooler swap, triple pillar pod guage, 2.5" leveling kit, 315/75/16 BFG KM2 Krawlers
dirtboy33 is offline
post #2 of 3 Old 12-16-2013, 08:59 AM
CSIPSD's Avatar
All the blocks are more or less the same. 94.5 blocks have some slight differences but nothing to worry about.
I would look for a 96-97 block and go from there.
How do you know the block is cracked?
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 3 Old 12-16-2013, 12:38 PM Thread Starter
dirtboy33's Avatar
Ok thanks. With it running lay under it look up on driver side and see a 2 inch crack dripping oil back by the flywheel housing.
