Diamond eye exhaust - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-07-2013, 08:47 PM Thread Starter
Diamond eye exhaust
I just installed a 4" diamond eye turbo back straight pipe on my 99, and for about 5 minutes of driving there is a sound coming from the engine. It sounds like a droned out vacuum. After five minutes the sound goes away.
Any ideas what this could be? I checked for leaks when in ideal and can't find any...
Kyle.ehey is offline
post #2 of 8 Old 12-07-2013, 09:00 PM
lookin4myPSD's Avatar
This is a shot in the dark, but is your EBPV acting up? broken tube or anything like that? because it may have been something that you never noticed before because of the stock exhaust. is there any loss of power associated with it?
If you ever think something I post is ridiculous or uneducated, just remember that I probably learned it from here.
Early 99 F250 ECLB,
T-500, 6637, CCV Mod, Foil delete 4" downpipe to 5" straightpipe
TS 6 Position Chip (Will accept donations for custom tunes!), Bridgestone Dueler AT 285/75R16
Pro-comp Trans temp, Pyrometer, boost and HPOP gauges
lookin4myPSD is offline
post #3 of 8 Old 12-08-2013, 03:28 AM
ja_cain's Avatar
Most likely the EBPV. You could watch the actuator until the sound goes away to confirm.
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #4 of 8 Old 12-08-2013, 06:23 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
i second the ebpv.
how cold is it where you live?
the jet sound is just the ebpv closing creating load to help warm up the engine.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is online now
post #5 of 8 Old 12-08-2013, 07:15 AM
If you hear it, go in and pull the plug while its running to see if it goes away. Just be careful not to snag your hand on the belt. I had the issue (I broke the ebp tube off of the sensor a while back and crimped the end shut) and when I pulled the plug, the problem stopped. It'll throw a code but it won't set off the CEL.
Early 99 F250 ECLB,
post #6 of 8 Old 12-08-2013, 11:39 AM
Quoted: 258 Post(s)
dfuser makes a plug that will eliminate it and make the computer not throw a code.
post #7 of 8 Old 12-08-2013, 05:57 PM Thread Starter
Originally Posted by blue99stroker View Post
i second the ebpv.
The jet sound is while it's idling warming up, which I understand is normal, the sound it makes is when I'm actually driving it.
post #8 of 8 Old 12-09-2013, 06:44 AM
Cummins_Killer's Avatar
how do you like the exhaust? im debating on getting the diamond eye or the mbrp
Cummins_Killer is offline
