550 injector ?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 12-07-2013, 06:57 PM Thread Starter
550 injector ??
I have a hypermax h-2 turbo that I am going to be installing , looking at p I s 160/30 or 175/80's and full forces 160 stage 1 or 160 stage 2. Truck is for work, local stuff usually 30-32 k gvw, manual trans and mostly likely dp infinity setup. Looking for power and economy. Anybody running something close to this setup? Any thought?
Sent from AutoGuide.com App
treemover is offline
post #2 of 4 Old 12-07-2013, 07:21 PM
Thuglike's Avatar
P.I.S. 175/80's will be a nice complement to that turbo. Tuning will be key as well.
I ran this for a while and it was a nice clean ride. Great power and real good mpg.
My tuning was spot on as well and was the final piece to a great set-up.
Thuglike is offline
post #3 of 4 Old 12-08-2013, 04:31 AM Thread Starter
Did u run same turbo? How was the rpms and fueling? I have not had a chance to call but website said the 160's. Fuel in lower rpms and 175's fuel in higher rpms. How was drive ability and fuel economy
post #4 of 4 Old 12-09-2013, 11:28 AM
CSIPSD's Avatar
There called AC injectors... 160cc with stock nozzles.
Nice injector however I think you would be overall happier with the ones below
I ran a set of 175/173 injectors years ago that were just like that. Ran them with both a 38R and a standard H2e...
Cant beat P.I.S injectors, nor some good tuning from No Limit...
Fueling is based on Nozzle and tuning, the capacity of the injector means nothing.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
