ts6position Motor Bogged down - Ford Powerstroke Diesel Forum
post #1 of 10 Old 12-04-2013, 02:47 PM Thread Starter
02 F350 7.3 When i run the truck on my stock position everything is fine.... as soon as i switch to any of the 50-140hp setting the truck feels like it looses power.... like matt it to the floor its fine but when u have regular acceleration it feels like its searching for 3 and 4 and when it shifts from 2-3 it dies.... no engine codes no other problems... any ideas
chiefson is offline
post #2 of 10 Old 12-04-2013, 02:48 PM
Raul@Stealth Automotive's Avatar
was it burnt to your exact PCM code?
Raul@Stealth Automotive is offline
post #3 of 10 Old 12-04-2013, 03:01 PM Thread Starter
i had an issue with it from xdp wasnt flashed right.... i sent it to ts about 3 weeks ago and now its doing this.... they double checked the code before i sent it to them so yes i would assume so
chiefson is offline
post #4 of 10 Old 12-04-2013, 03:12 PM
sounds to me like a tuning error...
post #5 of 10 Old 12-04-2013, 03:17 PM Thread Starter
thats what i was thnkin.... i had a ts in my old truck and it didnt do this so thats what im gonna go with
chiefson is offline
post #6 of 10 Old 12-04-2013, 06:06 PM
Joel's Avatar
Quoted: 10 Post(s)
Could improper cleaning of the ECM cause this type of issue?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 10 Old 12-04-2013, 06:32 PM Thread Starter
I'm gonna go with not in my case because as stated before when my chip was installed prior to ts re flashing it it worked fine it just had an issue with the high idle file
chiefson is offline
post #8 of 10 Old 12-04-2013, 06:36 PM
Joel's Avatar
Quoted: 10 Post(s)
Makes sense. Must be tuning then
Joel is offline
post #9 of 10 Old 12-05-2013, 09:35 AM
Quoted: 3 Post(s)
PM Sent.
Want to see if we can assist.
Powerstroke.org Members Save 10%!
for News, Contests & Giveaways!
PM Me or Call @ 1-888-DIESEL4 x201
Jeremy@XDP is offline
post #10 of 10 Old 12-07-2013, 10:20 PM
DieselGod's Avatar
Send a message via Skype™ to DieselGod
For what it's worth, I have sold many of the TS 6 pos and every time there's been an issue it has been the terminals on the PCM not being clean enough...for the 30 min it will take, Try to clean them up a little more both sides with the scotch brite till every terminal is nice bright gold then wipe it down with an alcohol swab, then a gentle wipe with a lint free cloth before you install the chip...I have gotten all mine from XDP, Tyrant and Swamps with a zero programming error. Worth a shot maybe.
2000 F-350 Lariat Dually 7.3 PSD
Custom built tranny, B&W +3 qt pan,BD cooler w fan
Custom painted 1 off 430 litre slip tank
Custom built electric re-fuel on the fly system (Me)
TDS stock rate Injectors
TS chip by Tyrant Diesel (nice tunes Cale!)
Banks Technicooler
Snow Stage 2 meth/water injection
BD Thruster II turbo(non-California)
4" turbo Back straight pipe Exhaust w 6"MBRP tip
AFE Stage 2 Intake & Zoodad
BD Exhaust Brake
AMSOIL bypass filter
Coolant filter (me)
DieselGod is offline
