Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 08-27-2008, 07:05 PM
JohnQBuilders JohnQBuilders is offline
7.3 Waste Gate Control VS Wicked Wheel
Help Guy's,
Turbo Surge and the cure???
In the process of going through the first upgrade stage for this year, on my 2000 Super Duty 7.3 with 6spd 4X4. Typical upgrades, intake, exhaust, 6.0 cooler, minor upgrades on fuel system and DP tuner.
Now the turbo surge is not too bad with the stock motor currently except when towing 6,000 lbs up a 8% grade then you begin to notice it.
I am looking for options, at how best to eliminate this till next years turbo upgrade to a GT38R with more fuel and injectors.
Looking for some experienced information with the Turbo Master Waste Gate Mechanical control. I have read up on there web site about what there control devise accomplishes. Read the reviews ..... is there any one on this list using this unit on there stock 7.3 Garrett Turbo???
Has any one used both TMWGC with a upgraded "Wicked Wheel"? If so what was your experience with this??? Good or ???
Thank You,
John
http://www.dieselsite.com/index.asp?...ROD&ProdID=875
Old 08-27-2008, 07:12 PM
bigwhite7.3stroker bigwhite7.3stroker is offline
Dirty South Stroker
I had the wicked wheel when I had my stock turbo and yes it did help with surge a bunch and as for the Turbo Master don't know most on here just pull the red line off the end of the waste gate and plug it this way you build more boost and accomplishes the same thing for free
WELCOME TO ORG! ! !
Old 08-27-2008, 07:33 PM
CSIPSD CSIPSD is offline
The turbomaster will not help surge one bit, it is a great upgrade above the factory rod which will start to bleed as early at 5psi... All you need to ajust the turbomaster is a 10mm and a extention... very easy and slick!
Old 08-27-2008, 08:25 PM
Appreciate the info guys. Sounds as though it is going to be a Wicked Wheel and the Turbo Master Waste Gate Mechanical control till next year when I can spend more $$$.
Just wanted to say Taylor, Your new wheels and tires look great on that truck of yours. I noticed you put an O8 tail gate on that as well. I have been searching for one and the ladder set up. I believe I have located one. $$$$ and time.
CSIPSD, I noticed your HP and Torque Numbers you have at the end of description. Was it necessary to install Head Studs and Valve springs with 450 + HP???
The goal for my truck, is about that for next year.
John
Old 08-27-2008, 11:06 PM
John
If you can make 450hp below 40# boost then no, but at or around 40# the stock head bolts lift, and the valves start to float...
Penrose huh... my brother in law lives there... Next time I am out there I will shoot you a message.
Old 08-28-2008, 02:32 AM
todd todd is offline
my tranny hates me
i went with a wicked wheel and banks big head waste gate and all surge was gone
Old 08-28-2008, 07:08 AM
CSPISD,
Yes Penrose ..... nice quite small little town inbetween Colorado Springs and Canon City and Pueblo. Sits right in the middle of the of those three cities.
Right now it is very green here, 85 with 12 to 20% humidity depending on if you get a quick thunder shower in the late afternoon. I moved my family from Western Washington State. I really was tired of the rain and most climate. Here we have 350 days of sun on the average. Annual rain is 16" of rain.
If you do come out to visit your brother in law, please let me know. I would think it great to talk trucks and motors.
Learned some thing today. Did not realize 40#'s was the threshold for head bolts and valve float. If I were to stay at 35# and use Digital Propane Injection???? I have not spoken to any one with DPI yet, just read about it. Worth up too 100hp and with variable levels according to what the demand is calling for and with safety limits as well. Though I suppose for the price of the DPI I could have done the studs and valve springs and had $ left over..
Had you considered DPI before going with studs and valve springs???
John
Old 08-28-2008, 07:16 AM
Banks Big Head Waste Gate
Todd, after installing the Banks, does your boost build with out siphoning off as rpms or load climb till you reach your set boost safety level???
I had a 1990 7.3 IDI with the banks system on it and worked great. Just have never experienced the BBHWG.
How much are they????
Old 08-28-2008, 07:32 AM
drstephennix drstephennix is offline
Pickin up all the slack
Send a message via Yahoo to drstephennix
I have my wastegate unplugged and a wicked wheel on. Surge is no more!
Old 08-28-2008, 03:45 PM
my tranny hates me
yep shot right up had it adjusted pretty tight lets off around 36-38
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
