- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
And to add, if the option to balance the injectors is there, DO it. I don't feel that it is necessary for injectors under *160cc unless larger than stock nozzles have been installed. *There *MAY* be a cylinder pressure issue with trucks pushing PMR's. |
| Sponsored Links |
My opinon is as such, I've said it before but I'll say it again: IMO, stock rebuild or even Stage-1's should be OK w/o balancing. Reason: How many trucks are running on the roads that had an injector or 2 go out and they had those injectors replaced? I don't know and don't expect to get an answer, but it's a lot of trucks, and you can't tell me those trucks run for crap or are going to blow up because of it. IMO, when you go larger, Stage-2, 3 or whatever, the more fuel you push, the more there's a possibilty for each injector to be off a bit, thus balancing might help then. I've always said that balancing injectors is never a bad idea. If you want the absolute best running injectors money can buy, then pay the extra $$$. But is it necessary? IMO No. And of the hundreds of customers I've dealt with over the past 3 years, only 2 I've talked with wanted my injectors balanced. None of the other customers wanted to pay the extra $$$. At least in discussions with me. What causes out of balance? IMO, from what I've seen, it has to do with any single or combination of: 1) Worn nozzles. 2) Worn Plunger & Barrel assemblies. 3) Inadequate Poppet Valve travel due to wear. 4) Variety of lengths of Intensifier Pistons (only really noticeable at WOT). Last edited by DZL JIM : 08-27-2008 at 03:57 PM. |
Nope. Though I haven't been on there in awhile. Are you here to cause problems or contribute. Like I said in the begining I just want opinions on the subject not debate or arguments. Binder I would agree that the factory doesn't ballance the injectors as a set. I've never talked to anyone at the factory to verify this but they don't sell them as a set of 8 per se so I don't think that's the case. I think the only real ballance they do is make sure all the specs are within tolerance and call it good. Reportedly the PCM will compensate up to about 15% difference in flow on the injectors. Or more accurately 15% variance in cylender contribution. I have not verified this but it's what I've been told. But who wants their whole set of injectors being drug down because one isn't contributing as much as the rest? Jim thanks for your thoughts on this. I was hoping you'd chime in! Stroking I had a funny feeling that was the case. If it is constantly dribbling fuel from a stuck pintle or a bad o-ring the fuel that is in the cylender is displacing air and will greatly increase compression. This is why when you have a bad lower o-ring it sometimes knocks so bad. It's just that that cylender has way more compression. You've seen what this does as well as CSIPSD has when his pistons were toasted from it. |
stay on topic boys....
| Sponsored Links |
