Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 08-26-2008, 04:51 PM
dieseldan2005 dieseldan2005 is offline
If it aint a CAT itsa DOG
Need HELP!
Dave sent me a chip for my truck and i can't find the PCM code. He sent me the DP-tuner link and i took off the PCM harness and there is no white sticker on it. One side only has something writtten in black marker and the other has some numbers and letters stamped into the grey plastic, but nothing that looks like a PCM code. Are there any other ways to check for this code? I put the truck back together for the night so any help would be appreciated.
Old 08-26-2008, 04:52 PM
I also forgot, i tried to get the PCM out of the truck and i got it loose, but it was tuck for some reason. Anyone else have this trouble? I tried jiggling it but it wouldn't come past a certain point. All bolts were removed according to the diagram on DP's website.
Old 08-26-2008, 04:54 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
Did you disconnect the harness going to it. To disconnect the harness you have to do it from the engine compartment. It is bolted to the pcm.
Old 08-26-2008, 05:33 PM
yeah i disconnected that also.
Old 08-26-2008, 05:39 PM
HVAC SuperTech HVAC SuperTech is offline
Scott loves the Squirell
it is in there at an angle, you must pull up on the black housing, and out.
Did you take the bolt out of the black plastic housing also?
Old 08-26-2008, 06:12 PM
I took both bolts out of the housing and the one on the pcm connector out. I had the whole unit very loose but it was just stuck past a certain point. So now that i know to pull up and out, do you guys know of any other ways to identify my pcm code?
Old 08-26-2008, 06:18 PM
gtspowerstroke gtspowerstroke is offline
As I recall there is a flange on the back that kind of hooks in. You have to pull the back of the PCM toward the passengers side and it should come right out.
Old 08-26-2008, 06:27 PM
On the back cover, where a chip would go, there is a plastic cover that tells the code, or, if not there, look on the front of the PCM, where the wiring harness plugs in, and it should be printed on there too.
Old 08-26-2008, 06:32 PM
mnstroker mnstroker is offline
I had the same problem and it ended up being the 10mm sob in the engine compartment.
You do the 10k mod Dan?
