6637 mod, Now service engine light on? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-29-2013, 04:27 PM Thread Starter
700hauler's Avatar
Did the 6637 to my 01 today, now the "service engine soon" light is on. Is this common? I can get it scanned at the local parts store, just figured I'd check to see if this is a common issue after the 6637 mod that I can easily fix. Thanks in advance.
700hauler is offline
post #2 of 14 Old 11-29-2013, 04:34 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 278 Post(s)
did you disconnect the intake air temp sensor
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
post #3 of 14 Old 11-29-2013, 07:04 PM Thread Starter
700hauler's Avatar
I did. But I plugged it back in. I was suspicious of whether or not that was the culprit or not. Would it throw the code if it had been unplugged and then plugged back in? Should I just disconnect the batteries and see if it resets?
post #4 of 14 Old 11-30-2013, 03:25 PM
leave it disconnected and tucked into the wheel well.
'03 CCSB
6637
4" Lift
35" Duratracs
...More to come as money allows!
gentimmy is offline
post #5 of 14 Old 11-30-2013, 03:37 PM
Quoted: 278 Post(s)
I left mine connected and zip tied it to the filter.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
post #6 of 14 Old 11-30-2013, 04:08 PM
Joel's Avatar
Quoted: 10 Post(s)
I left mine connected, but I relocated to the bumper and now I use it as an ambient air temperature sensor since my truck is an XLT and doesn't have it.
But no you shouldn't get an engine light. Go back in there and see if you accidentally disconnected anything.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 14 Old 11-30-2013, 05:40 PM Thread Starter
700hauler's Avatar
I was going to disconnect the batteries today to see if it would reset...but before I got to it the light went out. Kinda weird. I did run it one time without the air temp sensor plugged in. The first time driving with the 6637 (and air temp sensor unplugged) was when the light came on. I plugged the temp sensor back in and the light stayed on for a while but then on my last trip to the store I noticed it had gone out. So Im assuming it was related to the temp sensor being unplugged...?
So can I not run with the temp sensor unplugged without the service engine light being on?
post #8 of 14 Old 12-01-2013, 03:29 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Mines plugged in still and havnt gotten any lights on either sounds like there a ghost in your wiring. All the IAS does is just adjust the amount of fuel the computer adds. The colder the air the more fuel it adds, the warmer the air the less fuel it adds.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #9 of 14 Old 12-01-2013, 04:47 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't think that is true.
My understanding is that the IAT sensor is used only to control the EBPV. If that's not the case I would like to know.
Joel is offline
post #10 of 14 Old 12-01-2013, 04:56 PM
Quoted: 278 Post(s)
The PCM uses the air temperature information to operate the Exhaust Back-Pressure (EBP) system and to determine the cold idle setpoint.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
