AFE vs. Snow Performance - Ford Powerstroke Diesel Forum
 2Likes
post #1 of 13 Old 11-29-2013, 08:27 AM Thread Starter
Lambo3244's Avatar
Quoted: 4 Post(s)
Morning fellas,
Hope you all had a good thanksgiving. Been thinking about doing the meth injection for my rig. However, there is the Snow performance kit and AEM. From what I hear Snow is supposed to be the sh**. Haven't heard much about AEM and it is much less. I have the cash to get either or but was curious if I was buying the name from Snow or am I getting a better product than AEM..
Thanks for any input guys
01
7.3L Powerstroke
PHP Hydra Chip
G2 Brute Diff Covers
4'' Straight Pipe
Rigid Industries LEDs
AFE Stage II Intake
AMP Power Steps
BD Comp. Wheel
Fox 2.0 Factory Series Reservoir Shocks
Fox Dual Steering Stabilizer
Katzkin Leather
Lambo3244 is offline
post #2 of 13 Old 11-29-2013, 11:40 AM
Thuglike's Avatar
Neither!!! Both are junk when compared to Cooling Mist. Cooling Mist uses the best pumps on the market and have, by far, the best controllers.
Water Injection, Methanol Injection, Alcohol Injection Systems | water injection Coolingmist
Thuglike is offline
post #3 of 13 Old 12-02-2013, 07:05 AM
CSIPSD's Avatar
Agreed...
I've run Snows, and Cooling Mist...
Cooling Mist hands down is a better set up, better pumps, better controlers, better nozzles.
I've run water injection for over 10 years now.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 13 Old 12-09-2013, 06:25 PM
methanol injection in terrible for your engine. I've not seen any longevity out of any engine I've installed the snow/cooling mist on. My recommendation is to stay away from the water/methanol injection.
7.5stroker is offline
post #5 of 13 Old 12-09-2013, 08:26 PM
Thuglike's Avatar
Ran it for 5 years with zero problems. Water/meth is the safest injection system you can use..Unless your are completely retarted you CAN NOT hurt the engine!! The nice thing about the Cooling Mist controllers are all the safties built into it. The ONLY people that have hurt engines on water/meth were those looking to make power with it. It is a cooling system and should only be used to lower egt's.
GSchretter likes this.
Thuglike is offline
post #6 of 13 Old 12-09-2013, 08:40 PM
alright ******* no need to be calling anybody a retard and quite frankly go f**k yourself. But you are right.
post #7 of 13 Old 12-09-2013, 09:25 PM
Thuglike's Avatar
I don't need a retard like you to tell me I'm right.
Now go wash your mouth out with a revolver.
Thuglike is offline
post #8 of 13 Old 12-10-2013, 07:15 AM
CSIPSD's Avatar
10 years... thousands of gallons of water... No issues.
I do believe your thought process is flawed.
I've had my truck strapped to a dyno with CP testing equipment on it. Running up to 50% meth.
Below 30% there is no CP spike that is noticeable. Above 40% and it gets hairy.
Exactly.
Use Fuel to make power, using drugs to make power never ends up good.
Joe
CSIPSD is offline
post #9 of 13 Old 12-10-2013, 08:20 AM
dannanw's Avatar
Quoted: 54 Post(s)
Garage
now thats funny right there
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #10 of 13 Old 12-10-2013, 05:27 PM
ok I should've worded my original statement different. you are definitely correct that you should not use water/meth to make power. But you can shove it where the sun don't shine. Cause I don't need an arrogant prick like yourself to be telling me what's right or wrong. Now go take your "retarded" *** and jump into a wood chipper. Then tell me whats right or wrong.
