Stuck in a jam! Injectors - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-29-2013, 08:13 AM Thread Starter
Happy Thanksgiving everyone! Ive got a 99 f250 7.3 forged rods not studed, 250k on chassis rebuilt engine at 160k due to rod failure. bought the truck for a 1000 bucks and that was the start of my powerstroke way of life. its a 99 extracab shortbed 2wd auto 4r100, 4in exh, intake, flashpaq tuner, but mostly stock id say. its been AN AWESOME truck and problem free. Where I stand now is I was coming out to az from ca to visit parents for Thanksgiving and I lost number one Injector, Luckily I brought out my snap-on solus tester and was able to run a buzz test and cct test and verified which cyl it is.... Ok sorry for the long story but wanted to give a quick background of the truck. Ive searched and searched but haven't found the info I need. im very green when it comes to huei and these injectors. due to the mileage I want to replace all 8 not just the one, the truck is in az I live in ca so I was gonna pull em rent a car drive home and ship em out this Monday morning. whats the best bang for your buck place? I read sooooo much different stuff. I wanna go just a little bigger if possible maybe stage 1? just don't want to have to open a can of worms and have to do hpop, turbo, live tunes at the same time. just wanna get the truck back up and running. If im gonna spend the money on injectors just don't wanna buy stock ones is all. what do you all recommend? Thanks
-Jake-
JakeLake is offline
post #2 of 6 Old 11-29-2013, 05:21 PM
Joel's Avatar
Quoted: 10 Post(s)
I like "No Limit Tuning and Design"
They'll sell you Stage 1 160/30's with free custom tunes for like $1400
If you need a TS style chip to run the tunes (and you will) that's only like $250 I think
With that and maybe a new style turbo wheel you're good to go without live tuning and hpop upgrades.
Are you sure that you lost an injector though? Look into all the UVCH stuff and make sure it's all plugged in where its supposed to be.
This problem you're having may only need the 50 cent mod to fix
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #3 of 6 Old 11-29-2013, 05:40 PM Thread Starter
ok ill check them out. thanks. I know that 160 is the cc amount of fuel but what does the 30 stand for in 160/30?
JakeLake is offline
post #4 of 6 Old 11-29-2013, 06:00 PM
usteffenhagen's Avatar
I agree with the UVCH comment that Joel made. I did the 50cent mod after my passenger side harness came disconnected, worked like a charm
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #5 of 6 Old 11-29-2013, 06:36 PM Thread Starter
if the undercover valve harness came unplugged I would loose more than just one injector though, I would think. Its come unplugged before and have lost the entire bank. repaired cleaned and secured so wouldn't happen again. I ran A CCT test and got cyl 1. prior to this happening with a CCT test no faults present. With 250 miles on stock set of injectors I assume its time and their done. Will pull valve cover in the morning and we'll see whats up.
JakeLake is offline
post #6 of 6 Old 11-29-2013, 06:54 PM
Joel's Avatar
Quoted: 10 Post(s)
The 30 stands for 30% larger than stock sized nozzles
The large nozzle allows your tuner to dump the more fuel with less pulse width. You can only utilize so many CC's of fuel out of the stock sized holes.
I would really look into every possible issue under there before doing injectors..... Unless of course you're excited about the added power, then by all means just go for it.
Joel is offline
