Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
  #51 (permalink)
Old 08-30-2008, 09:02 AM
1baddsl 1baddsl is offline
I got some money to spend on a chip, i was going to buy a edge evo. Untill i read this thread... I got a couple of questions about it now....
Does it install right under the dash like the programers?
What gauges are needed? (i got a 6 speed) and if i don't run gauges will it mess it up?
How much smoke do they blow on the smoke setting? i am looking in to stacks and i want a show if i buy them...
Thanks
  #52 (permalink)
Old 08-30-2008, 09:07 AM
Raul@Stealth Automotive Raul@Stealth Automotive is offline
Thanks
nope it does not plug into your OBD port... you actually have to remove your PCM and put it in their....
you only need a boost and pyro gauge
and the smoke setting smokes pretty good... but it depends if you have an OBS or SD..
PM me if you have any questions or want a package deal with the gauges and the TW chip
-Raul
  #53 (permalink)
Old 08-30-2008, 09:08 AM
PSD0389 PSD0389 is offline
OBS- Old But ***y
Send a message via AIM to PSD0389
It does not plug into the OBDII port like a programmer it goes directly into the pcm, if you need a full write up for the install of the chip send me your email address and ill send the write up to you. The guages you should get are a pyrometer and boost guage and not having guages with the chip wont mess anything up but you need them to monitor everything with all the performance that will be added with the chip. If you talk to Raul@stealthautomotive he can hook you up with the chip and gauge combo. Definitely do a TW over an evo
Heres a video of my truck on the smoke setting but yours will blow more smoke since you have larger injectors, etc.
  #54 (permalink)
Old 08-30-2008, 09:09 AM
OBS- Old But ***y
oops raul got to him first, so we basically said the same thing
  #55 (permalink)
CloverLeafFarm CloverLeafFarm is online now
you must install the tw chip into the pcm
you will need boost gauge, motor temp gauge and i don't believe you will need a trany temp because you have a manual, you can run it without gauges but you have to be easy on it, don't know much about the smoke setting yet, my tw isn't installed yet
  #56 (permalink)
Old 08-30-2008, 09:10 AM
you guys beat me to it
  #57 (permalink)
Old 08-30-2008, 09:12 AM
1995psd 1995psd is offline
I run premium diesel here
Thanks
you will need to pull your pcm, and plug it in and mount it, (the stage knob) that shouldnt take maby 20 min to have it in
you should just need boost and pyro gauges and the gauges dont efect the chip but it lets you know when you are getting your engine way to hothttp://vids.myspace.com/index.cfm?fuseaction=vids.individual&videoid=39525 574
and for stacks, pm me!
smoke-
  #58 (permalink)
Old 08-30-2008, 09:48 AM
RadarRider RadarRider is offline
Locomotive Breath
I AM SOOO JEALOUS!!!
  #59 (permalink)
Old 08-30-2008, 09:59 AM
not for too much longer radar
  #60 (permalink)
Old 08-30-2008, 10:01 AM
try this link!
MySpaceTV Videos: 1995 powerstroke tw tuned bull haulers stacks by Durawhat???
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
