fuel pressure - Ford Powerstroke Diesel Forum
post #1 of 10 Old 11-26-2013, 06:07 PM Thread Starter
fuel pressure
I have a 2000 f250 7.3 and I was wondering sometimes my fuel presuure is running 75-80 psi is that too high? And if it is is it hurting anything?
honda144 is offline
post #2 of 10 Old 11-27-2013, 01:56 AM
blue99stroker's Avatar
Quoted: 244 Post(s)
that is too high.
could damage the pump, seals etc.
ideal is between 60-70
is this fuel pressure at idle or WOT?
99.5 f250 7.3 4x4 260k FF 160/30, PHP Hydra, S&B CAI, 4" Exhaust, RR Billet Wheel, Autometer Gauges, Transgo, Non-Ebpv Pedestal, High Flow Outlet, 08 Tow Mirrors.
Dad-2000 7.3 4x4 110k miles, Autometer Gauges, Superchips 1705, 6637, 4" Exhaust, BD Billet Wheel, TruCool Max
blue99stroker is offline
post #3 of 10 Old 11-27-2013, 10:07 AM Thread Starter
That's at idle and how do I turn it down if it is.
honda144 is offline
post #4 of 10 Old 11-27-2013, 02:19 PM
Quoted: 244 Post(s)
what did you do to achieve higher fuel pressure?
with the stock fuel pressure spring in it usually holds at 60 idle then drops to 50 at WOT.
post #5 of 10 Old 11-27-2013, 02:38 PM Thread Starter
I haven't done anything for fuel pressure I have a ts programmer, afe intake, and 4inch exhaust and its mainly that high right after I get fuel.
honda144 is offline
post #6 of 10 Old 11-27-2013, 04:06 PM
Justin@DP-Tuner's Avatar
Quoted: 45 Post(s)
What are you monitoring fuel pressure with?
80psi is too high, and the main cause for concern is leaks.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #7 of 10 Old 12-07-2013, 05:52 PM
I get 80-90 at idle and have for 5 years with a stock pump, no leaks. I put a gauge in an old filter cap, how else are you supposed to read fuel psi?
rffpsvb is offline
post #8 of 10 Old 12-07-2013, 08:08 PM
Joel's Avatar
Quoted: 10 Post(s)
Most people remove the plug on the back/left of the fuel bowl and run it from there.
If you run a gauge into the cab you can see what it's doing in. Conditions other than idle.
Are you sure that the gauge you're using is accurate? Because not only is 80 psi too high, it's nearly impossible for it to be that high if the system is in fact stock.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #9 of 10 Old 12-07-2013, 10:16 PM
I once did the bb mod, but I'm pretty sure I removed it later on cuz it didn't change the fuel psi, all I know is it doesn't leak and my truck is quieter than any other 7.3 I've seen, besides that four inch gaping hole coming out my tail pipe
rffpsvb is offline
post #10 of 10 Old 12-08-2013, 07:28 AM
Quoted: 244 Post(s)
the bb mod was for obs 7.3's not us superdutys'
