BOV - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-21-2013, 04:47 AM Thread Starter
BOV
whats the good/bad of having a blow off valve? where are they normally mounted ?
adennis41 is offline
post #2 of 8 Old 11-21-2013, 10:55 AM
dannanw's Avatar
Quoted: 65 Post(s)
Garage
I'll do you a favor before you get flammed really really bad google it and just dont put one on. it's that simple, and check out on google what a external wastegate turbo is (on most diesels)
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #3 of 8 Old 11-21-2013, 11:07 AM
schlutzer's Avatar
Quoted: 18 Post(s)
They exist... they do prevent the bark you get on letting off, especially when shifting if your truck is stick.
The one I can think of costs $700... Yes the turbo bark does put stress on your turbo, but people aren't regularly blowing the 38's to pieces. Besides you probably have a stock turbo, which you can have rebuild for a couple hundred if it does eventually fail.
The reason BOV's are so expensive for diesels is they must be electronic. A regular BOV or Bypass valve on a gas engine works on the pressure wave from closing the throttle plate. Diesel's don't have a throttle plate therefore a regular one does not work, it will do sweet nothing.
Please check out my 7.3 Enthusiast Facebook group! All are welcome!
schlutzer is offline
post #4 of 8 Old 11-22-2013, 01:25 PM
Thuglike's Avatar
Alot of the higher hp 6.4 guys have them on their twin set-ups. Especially those running with a vgt. it keeps that bad boy safe from overspinning.
Thuglike is offline
post #5 of 8 Old 11-24-2013, 08:53 AM
machinestheman's Avatar
What exactly is stressed when you let off the throttle that would warrant the use of one anyone have one and would like to rationalize why
01 f 450 6sp 4WD
DIY intake with prefilter, CCV mod, IAH delete, Granatelli big G monitor with electronic fuel pressure sender, sinister diesel coolant filter, muffler delete and hollow cat, IH bellowed up pipes, polished intake spyder, 203 thermostat, billet fpr housing, hpx hard line.
machinestheman is offline
post #6 of 8 Old 11-24-2013, 08:49 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That's a turbo bark. (0.55 seconds in)
What's happening is all the boost pressure from the intake, intercooler piping, and intercooler is rapidly exiting through your air filter.... in other words the air is going the wrong way.
This causes your turbo wheel to go from spinning really really fast, to almost stop, back and forth until the pressure dissipates. Causes stress on the turbo.....
Will it make it blow up tomorrow? no
. Will a BOV help? yes
Is a $700 BOV worth protecting a turbo worth less than that? hell no. That's why aside from high boost non wastegated builds you don't see them in much use.
The Following User Says Thank You to schlutzer For This Useful Post:
the1laf (11-27-2013)
post #7 of 8 Old 11-25-2013, 06:10 AM
HunterER7's Avatar
turbo bark explained - YouTube
great explanation. made me giggle a little but you are right, sure as hell not worth the buy. I get mean turbo bark. its crazy. my girl will be in the truck and she goes, "what the hell was that?!" haha
7.3 Crew Cab Long bed.
Stage 2 AFE intake, 4" MRBP turbo back, Stage 2 Full Force injectors, Adrenaline HPOP, Driven diesel Regulated return fuel system, Custom tuned TS 6 position chip, Edge evolution CTS gauge, Built Trans
Estimated. 380-450 hp
HunterER7 is offline
post #8 of 8 Old 11-25-2013, 12:53 PM
schlutzer's Avatar
Quoted: 18 Post(s)
That's not my video lol that's just a random one I found.
