Nitrous!Good or bad idea? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-20-2013, 06:21 AM Thread Starter
powerstroke1098's Avatar
Talking Nitrous!Good or bad idea?
I have a 2000 7.3 zf6, I have 160/80's, a regulated return, and tuning from gearhead, nothing else really that adds a drastic amount of power there just supporting. My truck goes pretty good but obviously I would like more power if I can get it. Would nitrous make it pop? and if not would it be worth it for such a small build, it smokes but not excessively so I figure at a minimum it would clean that up but would the spike in CP be dangerous? Also what else could I add to make more power, I don't think I need more HPO, and I think I have plenty of fuel supply for such small injectors correct? so other than injectable stuff like nitrous, propane and water-meth I am really at the mercy of my injectors right? I fret every day that I didn't just buy big hybrids. I'm planning on buying another truck soon (if I can find a clean one) and doing a pretty large build so should I just hold off on what I have now with this truck?
2000 Ford SCLB 7.3l F350 Zf6
Rosewood Stage II 160/80% Single Shots
Valair 500hp SD Clutch
TS Chip with Tuning from Matt@Gearhead
MBRP 4" TurboBack
Riffraff Frx & Riffraff Hpx
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
powerstroke1098 is offline
post #2 of 12 Old 11-20-2013, 09:37 AM
CSIPSD's Avatar
What use do you want out of Nitrous?
Just for racing now and then or?
Are you studded?
Without knowing your fuel pressure its hard to say if you have fuel issues.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 12 Old 11-20-2013, 01:33 PM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
Oh ya nitrous will make her pop. Pop the heads right off from it lol. Do you have a stock turbo or have you updated that?
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #4 of 12 Old 11-20-2013, 08:35 PM Thread Starter
Stock turbo, and its not studded. My fuel pressure stays at 65psi then drops to 55 at wot, i've heard 60psi is sort of a baseline.
MBRP 4" TurboBack
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
post #5 of 12 Old 11-20-2013, 08:36 PM Thread Starter
I would be planning on a small shot if it was even possible without lifting the heads. Also CISPSD did you see a hp gain from water injection or just a reduction in EGT's? Thanks for the help by the way!
MBRP 4" TurboBack
K&N Intake
AIH Delete
Ladder Bars
Glowshift "Gay"ges
post #6 of 12 Old 11-20-2013, 09:51 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't know about nitrous specifically for the 7.3
But as a general guideline, nitrous is safe so long as you don't over do it and retard the timing for bigger hits.
If I was going to do it, I would only do a 50-75 shot and use and rpm window switch to prevent hitting it below 2500rpm and spiking pressure to much.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #7 of 12 Old 11-21-2013, 04:04 AM
Get yourself a regulated return and a fuel lab pump or a SRP 1.1 HPOP. I gained over 200ft/lb of torque with both of these installed on the same setup. MY hpop held 2400psi before. IN addition fuel pressure was like yours.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #8 of 12 Old 11-21-2013, 12:00 PM
dannanw's Avatar
Quoted: 63 Post(s)
Garage
wayyyyy before that for the OP is a turbo of some kind... NOS=dyno queen or Track only part.
What this nation needs is cleaner thoughts and dirtier fingernails...
dannanw is offline
post #9 of 12 Old 11-22-2013, 01:51 PM
RPM Tim's Avatar
OP says he has regulated return in the first sentence.
I would definitely pass on nitrous for your truck. You could better spend your money elsewhere for more power. You would likely need bigger injectors for a hit big enough to amount to anything, unless you just want to spray it to say you did.. leave that to the Honda kids.
2002
250 CCSB 4x4 7.3
stock~ diy B085011 / DEP 5" Turbo Back w/muffler / Phoenix chip
RPM Tim is offline
post #10 of 12 Old 11-24-2013, 10:00 AM
machinestheman's Avatar
Nitrous is not a fuel all your doing is changing the amount of oxygen in your combustion generally speaking your turbo can get plenty of forced air into the engine most serious builds just use the nitrous to emulate boost until the turbo catches up but it can be added to the turbo as well long story short regardless of what you do you will need a custom tune so before you do it talk to your tuner he should be able to tell you what your limits are and generally if it's not a track queen your wasting time and money good luck
01 f 450 6sp 4WD
DIY intake with prefilter, CCV mod, IAH delete, Granatelli big G monitor with electronic fuel pressure sender, sinister diesel coolant filter, muffler delete and hollow cat, IH bellowed up pipes, polished intake spyder, 203 thermostat, billet fpr housing, hpx hard line.
machinestheman is offline
Tags
7.3 , fuel , hpop , nitrous , turbo
