Nitrous Injection Location 7.3 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-19-2013, 07:55 PM Thread Starter
I was wondering where the best location would be to inject nitrous into a 7.3. I really do not want to go pre-turbo. I was thinking about injecting it, where the Air Heater Delete plug goes. I have a fogger/ dry nozzle.
00 Excursion 7.3 (1.0 Ex. hsng., 3.5" downpipe, Aero Muffler, Banks WG, Banks Comp. Wheel, AFE Stage 2 Air intake, HPX, IAH delete, DP- Tuner F6, Riffraff Boost Fooler, Melling Oil Pump), Fuel lab 41402 pump and regulator, fuel bowl delete, 910 Comp Springs/Shims, DI Pushrods, Swamps HVHF IDM, SRP 1.1 HPOP Dieselsite trans and coolant filter, 203* thermostat, Sonnax valve 0.427 and tricumulator springs, Lift, MM Hubs, 35's and 3.73s, 08 diff cover, Hellwig rr. bar
326RWHP @ 731RWTQ.
572ysc is offline
post #2 of 6 Old 11-20-2013, 09:41 AM
CSIPSD's Avatar
All that work... and stock injectors still?
And now your adding Nitrous?
A set of 160's and a 38R would have put you 75+hp above where you are now, and run better.
Yes, the AIH would be fine.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 6 Old 11-21-2013, 04:07 AM Thread Starter
Well I want to add the nitrous kit and then go to 250/100 ff injectors and them get a 468 t4 setup. I already got the studs and its a forged rod engine. I know I am at the limit with the stock sticks. (I am not using the nitrous until I get the sticks).
326RWHP @ 731RWTQ.
572ysc is offline
post #4 of 6 Old 11-21-2013, 03:08 PM
CSIPSD's Avatar
I'd hope you would not use the nitrous with the 250's... but hey, I like to make hp with fuel, not drugs!
Joe
CSIPSD is offline
post #5 of 6 Old 11-21-2013, 04:03 PM Thread Starter
Nitrous is ok if you use it wisely. May people just think that the more is better. If used in the appropriate rpm and boost level it actually helps clear some of the smoke. That's like saying don't run a smoke tune, because it washes out the cylinder wall and is also not healthy for a motor.
326RWHP @ 731RWTQ.
572ysc is offline
post #6 of 6 Old 11-21-2013, 04:36 PM
CSIPSD's Avatar
Ever seen what Nitrous does to Cylinder Pressures...
but you go right ahead.
Joe
CSIPSD is offline
