Trans temp gauge not working - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-17-2013, 10:39 PM Thread Starter
I bought a matching Isspro trans temp gauge to go with my Pyro and boost.
Its an EV1 gauge. I put the probe in the threaded trans plug and mounted the sender on my firewall. I havn't had the gauge in the truck though until yesterday because I didn't have a big enough pillar. The lights and everything work on the gauge, but it hasn't moved off of 100 since I put it in. It's been about 10* F lately but truck has been in the shop before driving so surly the transmission can't be 100* after 10 miles.
Does anyone have any ideas? Should I contact Isspro or diesel manor? (the place I bought it from)
99' F-350 CCLB 92,100 miles ▬ 05 headlights 4" exhaust 6637 Gauges F650 dash blue LED interior HID Headlights & offroad lights 20" LED lightbar PHP Hydra 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #2 of 7 Old 11-18-2013, 02:50 AM
Behavior Modificationist
AgTires4295's Avatar
Quoted: 19 Post(s)
Youd be surprised at how long it sometimes takes. Before going any further, I'd run it longer than just 10 miles and rule out a cold trans.
2001 7.3L
Pro Comp 6.5" Lift
Pro Comp 16x10 Alloys
35x12.5 Nitto Mud Grapplers
Sky Jacker Hydro 7000 Steering Stabilizers
K&N CAI JUNKED For A 6637
Straight Piped Dual 4"
Jasper 4R100 (Rebuilt in '05)
Tru-Cool Max
Dieselsite Coolant/Trans Filters
ISSPRO EV2 (Boost, EGT, Trans)
Centramatics
EBPV Switch
'07 Headlight Conversion
Foil Delete
Zoodad
Monitoring with Torque
AgTires4295 is offline
post #3 of 7 Old 11-18-2013, 04:03 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I doubt there is anything wrong. With that temp and an empty truck it may never come off 100. Hook a trailer to it and make a run
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #4 of 7 Old 11-18-2013, 06:19 AM
DieselManor's Avatar
Usually Your trans temp gauge will not read until it's over 30 degrees outside, and that's after driving it for a good 20 min. Probably nothing wrong with it. I have the exact same TT gauge in my 2001 and it seldom reads at all this time of year.
David Murphy
DieselManor is offline
post #5 of 7 Old 11-18-2013, 09:26 AM
hansel's Avatar
Quoted: 94 Post(s)
If you drove only 10 miles with that temp being outside your transmission is still cold, I have a 6.0L cooler and when the temp is in the 40's outside it takes awhile too reach 100*.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #6 of 7 Old 11-18-2013, 03:30 PM Thread Starter
Well, thanks for the input guys, The truck was in a nice warm shop all night then immediatly started driving so I figured that the trans would warm right up.
Its about 70* in the shop, so I suppose the transmission would have to raise 30* to even register on the gauge? That wouldn't happen in 10 miles?
You guys are probably right though. Maybe I will plug in my transmission pan heater tonight and see if I can get it to register on the gauge.
But thanks again.
peter379 is offline
post #7 of 7 Old 11-18-2013, 09:54 PM
03ranger30's Avatar
Mine does the same thing. I have a relatively short commute to work and it rarely ever moves over 100* unless I am driving really hard.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
