What the He11 would have caused this!!!????? - Ford Powerstroke Diesel Forum
post #1 of 14 Old 11-15-2013, 11:06 AM Thread Starter
027.3's Avatar
Ok, I've owned my '02 CCSB for about 7 years. I've got a few mods done as in my Sig. I was changing my filter like I do every oil changed and happened to look down the intake tube at the turbo wheel and it was all beat up like something got sucked through. Now for all I know its been like this since I bought it, I've never really looked at it before. Luckily I had a WW that I was trying to sell (no takers) so I just spent the last hour or so changing it out. I bought my truck used with 72,000mi and it now has 145,000mi. I've never had it apart and it has always ran good with around 20psi of boost. What do you guys think??
'02 7.3 4 door 4X4 -- Leveled, WIcked wheel,4" turbo back w/ 5" tip, 6637, foil delete, zoodad mod, hutch/Harpoon mod, glow shift Egt & boost, 4- 7" 55w HIDs
027.3 is offline
post #2 of 14 Old 11-15-2013, 11:11 AM
03ranger30's Avatar
Looks like your intake is letting dust or something in. Make sure your connections are tight.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #3 of 14 Old 11-15-2013, 11:28 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well something big f-ed up your wheel. My guess is a chunk of your wheel cracked and flew off and screwed up the rest of the blades until it passsed through
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #4 of 14 Old 11-15-2013, 11:36 AM Thread Starter
027.3's Avatar
Dust would cause damage like that?? Wow!
027.3 is offline
post #5 of 14 Old 11-15-2013, 01:18 PM
Just think how fast that wheel is going, just takes small dust & makes it highly abrasive.
letitsno is offline
post #6 of 14 Old 11-15-2013, 02:10 PM
Gaius's Avatar
Quoted: 43 Post(s)
Dust didn't do that, something relatively big smacked it.
05 F350 Crewcab
98 Jeep TJ - wheeler
Gaius is offline
post #7 of 14 Old 11-15-2013, 03:00 PM
ja_cain's Avatar
Hell, steam that condenses in steam turbines causes serious erosion on the rotors especially at the tips where the velocity is the highest. Fines are more than likely going to look more like erosion (especially at the tips of the compressor inducer) than large chunks removed from the compressor. I think you are right in that it was probably something larger than dust especially considering were it is relative to the center of the rotor.
Sent from AutoGuide.com App
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #8 of 14 Old 11-15-2013, 03:40 PM
blue99stroker's Avatar
Quoted: 258 Post(s)
ouch that looks bad.
i would definately put the new wheel on and check to make sure this doesnt happen again
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #9 of 14 Old 11-15-2013, 03:51 PM
Quoted: 784 Post(s)
Definitely not dust. Dust erosion would be more smooth. Looks like previous owner failed to tell you something.
Something got left inside the intake when apart. Went for a joy ride and s..t. I remember where that piece is now. SOB.
Corey@CNCFAB is offline
post #10 of 14 Old 11-15-2013, 04:02 PM
ja_cain's Avatar
Exactly! Like hitting it with a piece of sandpaper. It is usually most apparent at the rotor tips were the velocity is the highest. I'll have to take a picture of mine to illustrate this (probably product of K&N drop in filter).
ja_cain is offline
