1999 Powerstroke Boost Limited? - Ford Powerstroke Diesel Forum
post #1 of 16 Old 11-13-2013, 09:01 PM Thread Starter
Hey guys so i just wanna say that I am new to the diesel scene. So sorry if any of this sounds dumb.
I just recently purchased a early 1999 7.3 L Powerstroke F350 Super Duty with the Automatic 4R100 tranny. It has 207,000 miles on it. A few of the upgrades include: AFE Cold Air Intake, Edge Evolution chip, Banks Wicked Wheel turbo wheel upgrade, 5 inch straight pipe turbo back exhaust with a 4" downpipe, Aftermarket Fuel Lab Fuel Regulating system, 140 hp injectors, Aftermarket fuel injector rods (dont know the name). So basically all of this was installed on the truck when i purchased it... (for 9000!)
My question is that even with the truck in extreme mode 100 hp and 200 torque even when i hammer on the gas I still can only push 20 lbs of boost. I am curious if some sort of a computer fooler would work to help let it spool up to around 25-30. I know that the hp and torque is there i am just wanting to spool up more boost. Im planning on playing with the shift points programming on the chip. I have also heard that you can use a 4.7 V 1 W Zener diode as a turbo fooler. Does this work? If not im planning on getting a boost fooler kit that will plug into my system.
I guess what im getting at is how do i make more boost? Will a some sort of a computer fooler work?
Powersmoke1999 is offline
post #2 of 16 Old 11-13-2013, 09:37 PM
First things first... Get rid of the edge! Get a tuning company like PHP, TonyWildman, Beans, Gearhead to write you custom tunes based around the mods that you have in your truck. It will make a world of difference!
99' F-350 CCLB 92,100 miles ▬ 05 headlights • 4" exhaust • 6637 • Gauges • F650 dash • blue LED interior • HID Headlights & offroad lights • 20" LED lightbar • PHP Hydra • 08 Taillights
97' F-450 Powerstroke 4x4
03' Peterbilt 379 650+ CAT
02' Cummins 3500 flatbed
peter379 is offline
post #3 of 16 Old 11-14-2013, 08:49 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
You will need a Boost fooler. Mech one.
FYI..stage 4 140 hp single shot injectors ..no such injector
We can help with your performance mods.
CT Performance, Inc. is offline
post #4 of 16 Old 11-14-2013, 10:46 AM Thread Starter
So a electronic boost fooler doesn't work? or doesn't work as well as a mechanical one? What are the advantages of the mechanical one.
post #5 of 16 Old 11-14-2013, 10:48 AM
Quoted: 3 Post(s)
They don't protect the map from hi boost pressures for one.
The majority of the pressure relief set ups I've seen blow off actual boost and do not isolate excess boost to the MAP side only, leaving the manifold pressure able to rise. The electric modifications don't allow MDFR (Mass Desired Fuel Rate) on the low end early enough since they mitigate the overall boost by a percentage.
The Following User Says Thank You to CT Performance, Inc. For This Useful Post:
Powersmoke1999 (11-14-2013)
post #6 of 16 Old 11-14-2013, 02:25 PM Thread Starter
What stage do you think my injectors are then? I have the paperwork they are 140 hp class B injectors so i think that means bus class. Im new to this stuff so I'm curious what i've got.
post #7 of 16 Old 11-14-2013, 02:43 PM
Quoted: 3 Post(s)
Who's inj's what are the specs.
DT466s and I530E injectors are B codes. But you need to know what's inside them, nozzles used etc...
post #8 of 16 Old 11-16-2013, 05:42 AM
Im_Strokin_ur_Cummins's Avatar
Location: Lowville, New York. Studying Mechanical Eng. @ Suny Canton
If your turbo is still stock thats a likely reason you arnt seeing high boost the D66 is the one that will fit our E99 trucks. As for a custome tune that up to you I got one and it was harder on my tranny then my edge evoulution was so I went back to the edge and unplugged the custom chip that are "way better then canned tunes" some how. but again its up to you id say stick with what you have for now.
FUELED BY HATERS
Jack'em up high.Fat chicks cant jump!
E99 7.3 F-250XLT
304,345 miles and still running strong
ext cab
DIY 6637 Intake
5in straight pipe to Aussie stacks
PHP 6pos
Boost,tran,and EGT Gauges
4in lift
Some body rust and oil leaks
CB radio
Pretty Girl sittin next to me
Im_Strokin_ur_Cummins is offline
post #9 of 16 Old 11-16-2013, 07:24 AM
blue99stroker's Avatar
Quoted: 270 Post(s)
my cutom tunes shift firmer/harder than my superchips or edge did. but with way less flare or sloppy shifts.
but after 70k miles (i know i put it off) with my php i dropped the trans pan and changed the filter and fluid and their was ZERO material in the pan.
the original tranny in my truck was eaten by the previous owner, who of course, used an edge evolution
everytime i drive by the local tranny shop and see a 7.3 parked out front, they usually have a nice fancy EDGE sticker on the fender.
arent b codes hybrids, which are single shot injectors?
and unless someone loaded custom tunes on your edge programmer, your edge evolution would have tuning for split shots.
so something doesnt seem right. and if you had bigger injectors you would be seeing huge boost numbers with the stock turbo. which would blow it up sooner than later. and extremely high egts to boot.
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #10 of 16 Old 11-16-2013, 07:29 AM
the original tranny was eaten by the previous owner, who of course, used a edge evolution
Well there a big diffrance between firm shift and it slamming into gear. A TC thats unlocked for 4 to 5 seconds before locking back up and slamming into gear will break something faster then my old tride and true edge that shifts way better then my custom chip. This also goes along with the lower EGTs with a custom chip haha ya i seen higher with the custom then my edge ever gave me and my tranny shooting up to 160* within 10min of driving which the edge never did that fast even if i was hammering on her.
FUELED BY HATERS
E99 7.3 F-250XLT
ext cab
DIY 6637 Intake
PHP 6pos
4in lift
CB radio
