Intersting cheap way to keep a southern truck without plug warm in the winter - Ford Powerstroke Diesel Forum
post #1 of 34 Old 11-13-2013, 12:37 PM Thread Starter
7.3LDriver's Avatar
Quoted: 5 Post(s)
I bought my 7.3 from a south carolina dealer and it didnt come with a plug. I was thinking how i might be able to save some money so i went out and bought one of those infared lamps that they use to keep chickens warm. I also bought a 250watt bulb for it. Total it cost about $14. Last night i plugged it up and put it under the engine of my truck. It got down to 28 degrees with a 12mph wind. When i cranked my truck up in the morning it took just as long for the glow plugs to warm it up as it does in 70 degree weather!
E99 F350 eclb drw 7.3L 4X4
220,000miles
leveling kit
35" tires
Donaldson Replacement 6637 Filter
Diamond eye 4" TB
ts6 with informant6 monitor
180/30 full force diesel injectors
d66 turbo
Riff Raff HPX and FRX
valair clutch
Zoodad Mod
Cam-locker toolbox
7.3LDriver is offline
post #2 of 34 Old 11-13-2013, 01:43 PM
CSIPSD's Avatar
Ford 7 3 6 0 6 4 L Powerstroke Diesel Block Heater Cord | eBay
Ford Block Heater Kit Engine Heater Kit 1993 2003 Ford Powerstroke 7 3L Diesel | eBay
Or you could simply fix it right...
Na...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 34 Old 11-13-2013, 02:38 PM
blue99stroker's Avatar
Quoted: 270 Post(s)
did you look up underneath and see if its still ziptied there from the factory?
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
post #4 of 34 Old 11-13-2013, 03:47 PM
heisman01's Avatar
Quoted: 53 Post(s)
I'm sure it has a block heater tucked up under the bumper, you can also get a western glow plug relay and use 10w30 which helps a lot. I fired my truck right up this morning after sitting for over 12 hours unplugged in 20* weather. Only left the key forward for about 30 sec or so.
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #5 of 34 Old 11-13-2013, 04:26 PM
ja_cain's Avatar
I was recently having starting problems in the morning when the temps would drop below 40. Checked GPR and was not getting 12 volts on second large terminal. Would jumper it with jumper cables for 10 seconds and truck would start up. Without doing this i would have to crank it 3 or 4 different times and then it would smoke real bad for a couple minutes. Went ahead and bought new relay from Napa (109), installed it and measured current at over 70 amps. I knew it was working then. Truck started right up within 2 to 3 seconds of cranking with an outside temp of 25 and oil temp of 32 degrees. Here is a picture of the internals on the old relay. Note the carbon build up. A nitrogen filled relay would definitely be the way to go as long as it stays sealed it should not really accumulate any carbon on the contacts. The relay was cheap enough at 27 bucks and would be fine if it only lasted one winter and I had to replace it again next year. Took about 10 minutes to change out too.
JC
2002 F-350 SCLB PSD 4X4 6 Speed
ja_cain is offline
post #6 of 34 Old 11-13-2013, 04:36 PM
ja_cain's Avatar
Also, key was forward for around 15 seconds.
ja_cain is offline
post #7 of 34 Old 11-15-2013, 06:24 PM
hansel's Avatar
Quoted: 99 Post(s)
My truck came with a block heater, and I was living in South Florida when I purchased the truck brand new from Ford.
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #8 of 34 Old 11-16-2013, 04:32 PM
dentexpowerstroke's Avatar
Joe, come on man it would make way to much sense to track down an issue in the gp system and fix that. I'm usually don't fix anything either I just rig it to cover up the issues.
op, walmart sells starting fluid too if you're interested in using that to help cover up the issue too.
Sold 2001 f250 ccsb 4x4 400/400, dual terminators, swamps 80mm bfh, headers, bts and all the usual supporting mods. 715hp fuel only.
06 f250 ccsb king ranch
12 f250 lariat ultimate
dentexpowerstroke is offline
post #9 of 34 Old 11-16-2013, 05:35 PM
Quoted: 270 Post(s)
starting fluid......
post #10 of 34 Old 11-16-2013, 06:20 PM
juniorssrollin's Avatar
Quoted: 2 Post(s)
I like to park mine over a bed of hot coals...
:screwy:
2005 F350 CCLB FX4
2005 F350 CCLB FX4
juniorssrollin is offline
