need help with egt's while pulling - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-11-2013, 10:58 AM Thread Starter
Lets try again. Since my last post was hard to read. My truck is a 99 F350 swd cc with 300k miles. This past spring I replaced injectors,turbo and chip. New injectors Alliant 75 hp,turbo is Garrett Power Max, TS 6 position chip HI,stock,50,75,100 and 140. S&B intake,MBRP 4" and ccv mod already done.HPOP is not original but know anything other than that about it.I pull a 40' toyhauler FW,dry it weighs around 14k. When driving on relative flat ground to a slight increase in grade my EGTs will hit 1200 in 4th gear just to keep speed around 40. With the position on the chip @50. It seems like the truck hits a wall. I thought that it should be able to do a better job at pulling that weight. I love the truck and want to be able to do a better job at pulling the camper. Any ideas or thoughts? Thanks
wattser322 is offline
post #2 of 9 Old 11-11-2013, 11:39 AM
CSIPSD's Avatar
Ugh...
Find the period button. Find the shift key... That's painful to read.
What are 75 over injectors? Find out what CC and nozzle size they have. 75 over means dick.
Who's tuning on the TS "tuner" (assuming this is a TS chip)?
Everything didnt get upgraded... You threw larger injectors at a turbo that is nearly too small to begin with. You dont mention if you have intake or exhaust mods? You dont mention if you have a manual or auto...
Your running a stock HPOP with 300k on it, it might be fine, it might not be...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 9 Old 11-11-2013, 05:41 PM
Joel's Avatar
Quoted: 10 Post(s)
Are the injectors single shot or split shot? If single shot, do you have the correct tuning?
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 9 Old 11-11-2013, 06:48 PM Thread Starter
They are single shot. I was thinking of maybe intercooler as well. Thanks Joel
post #5 of 9 Old 11-11-2013, 06:57 PM
blue99stroker's Avatar
Quoted: 289 Post(s)
intercooler gives minimal cooling beneits.
whos tuning are you running?
and did you install 160/80's or a different stage 2 injector
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 9 Old 11-11-2013, 07:01 PM
Quoted: 897 Post(s)
Feedback Score: 3 reviews
If they are single shot on canned tunes, the trucks gonna run horrible. Crappy idle too.
Corey@CNCFAB is offline
post #7 of 9 Old 11-12-2013, 03:49 AM
Solid98's Avatar
Quoted: 9 Post(s)
Is this "50" tune a towing tune or just a canned tune? Might be too hot to be towing over 14k. Most tunes I have seen, the greater the towed load the lower the hp level. There is a reason there are "HP" tunes and "Towing" tunes.
Since you report you are in 4th gear at 40mph, I'm hoping you are talking about a 6 speed manual? What RPMs are you at?
01 F250 XL Ex Cab: RIP 12-15-2013
1999 F250 XLT 4X4 auto, Bully Dog 5" straight pipe, rest stock.
Solid98 is offline
post #8 of 9 Old 11-12-2013, 06:33 AM
CSIPSD's Avatar
Thanks for the edit... It doesnt have to be perfect, just readable.
Alliant doesnt make a 75hp injector... Find out EXACTLY what kind of injector it is. I suspect you bought new AC injectors which are 160/0 injectors.
What is your max boost?
What are your ICP pressures and duty cycles?
What is your fuel pressure under load?
What trans are you running?
Are you lifted or stock height?
Have you tried down shifting? When towing heavy the best way to bring down EGT's is to downshift and bring the RPM's up. It's nothing to tow with a 7.3 at 2600-2800 RPM's.
Sounds to me like your lugging the motor.
Joe
CSIPSD is offline
post #9 of 9 Old 11-12-2013, 10:26 AM
If this is an auto, I would NOT be in 4th gear at 40 mph at all. 45-55 mph is a nice place for third gear with OD locked out.
14k# fifth wheel is a huge wind load and a heavy weight. It won't be fast.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
