HP Oil Lines Again?! Please Help! - Ford Powerstroke Diesel Forum
post #1 of 20 Old 11-08-2013, 09:32 AM Thread Starter
Brettt's Avatar
I Keep having problems blowing up high pressure oil lines and im getting sick of it. First I had the OEM oil lines in the truck and i think they went cause they were just old, but I have had them replaced for the 3rd time now. Is there some kind of upgraded set of HP oil lines i could put in my truck so this doesnt happen anymore???
Thanks, Brett
2001 Ford F-250 Super Duty 7.3L Powerstroke.
Brettt is offline
post #2 of 20 Old 11-08-2013, 07:27 PM
i think you have other problems.new hpop lines should not be going out like that. i think stock lines burst at (5k may be higher or lower don't know)
2001 F-250 4x4 5.9 12v ppump built trans many more mods 500+hp
2006 F-350 4x4 ficm by ficmrepair with php hercules tune,arp studs,BulletProof EGR, sct with custom tunes
turbo098 is offline
post #3 of 20 Old 11-08-2013, 07:56 PM
broncomitch's Avatar
Maybe get the cross over oil line from riffraff
Said to equaliz the oil pressure between the oil rails to prevent oil pressure spikes.
L99 f250 7.3 powerstroke,
L99 hybrid turbo,
Built transmission,
TS, 6 position chip,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
FPR alum housing with black spring,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
06 axles and suspension,
09 steering box,
015 spring swap and shackle flip.
Saginaw PSP conversion,
016 front bumper,
Autometer&Torque app for gauges,
71 early bronco "rock crawler" 351w,c6,strong box,np205,1tons, 44"tires, ect ect.
broncomitch is offline
post #4 of 20 Old 11-09-2013, 04:27 AM
Riffraff Diesel Performance Parts: - HPX
L99 hybrid turbo,
Built transmission,
AIH delete,
4"to5" exhaust,
foil delete,
UMP intake,
Zoodad mod,
6.0 tranny cooler,
6.0 PS cooler,
06 dash swap,
09 steering box,
016 front bumper,
post #5 of 20 Old 11-09-2013, 05:40 AM
m j
pics of blown lines?
is the crimp failing or???
1997 F250 rclb 4x4, Comp910s, SRP1.1, Irate T4 s468,FullForce 350/200, homebrew efuel with i̶n̶ ̶t̶a̶n̶k̶ ̶a̶e̶r̶o̶m̶o̶t̶i̶v̶e̶ ̶1̶1̶1̶4̶2̶ A1000 5/8" drawstraw, Diesel Innovations fuel rail feed fittings, balljoint D60f Detroit Locker, zf5 sachs K70263-01CB ceramic clutch , Grizzly locker 10.25, 315/75/16 Wrangler MT/Windowed 7.3 Oct 9/14
m j is offline
post #6 of 20 Old 11-09-2013, 05:50 AM
Quoted: 780 Post(s)
I am pretty sure your IPR isn't working right. The HPOP is a fixed displacement piston pump. So if the relief (IPR) is stuck, it will over pressurize and something has to give. In this case, your hoses. Usually the non-servicable plug blows out.
Corey@CNCFAB is online now
post #7 of 20 Old 11-09-2013, 05:50 AM
Quoted: 780 Post(s)
Crossover line won't help this.
post #8 of 20 Old 11-09-2013, 02:23 PM Thread Starter
Brettt's Avatar
The Lines are blowing because the ones that I keep putting in are not the proper hp oil lines like you get oem from Ford, I keep getting them made from a shop, they fit and seem to work fine for a while, but I don't think they are able to handle the pressure that is going threw them, and they seem to be under some stress. I basically need help trying to find some sort of upgraded oil lines that I can put in so I never have this problem again. Any sites to look at, or stores, or do I just go to Ford?
2001 Ford F-250 Super Duty 7.3L Powerstoke. 6637 BHAF Air Intake, Beand Diesel 6 pos. Tuner, 8" Rough Country Suspension Lift "Rollin On 37's" 5" Exhaust with Stack
Brettt is offline
post #9 of 20 Old 11-09-2013, 02:30 PM Thread Starter
Brettt's Avatar
I didn't take a pic. There not going at the crimp, the one time I think it went cause it got kinked (no idea how) and once it blew right in the middle, and the last time it was close to the crimp. It seems like there not handling the pressure. Which wouldn't surprise me because there not actual hp oil lines made for a 7.3
Brettt is offline
post #10 of 20 Old 11-09-2013, 03:37 PM
m j
so what are they? hydraulic lines have pressure ratings written right on them? is it 4 wire hi pressure line? 4 wire should survive
m j is offline
