airdog systems - Ford Powerstroke Diesel Forum
post #1 of 9 Old 11-06-2013, 08:02 PM Thread Starter
airdog systems
What's the difference between the air dog 150 and the stage 2 air dog 165.
honda144 is offline
post #2 of 9 Old 11-06-2013, 08:05 PM
Macon's Avatar
I have heard they are both useless if you do the Hutch mod. I don't have personal knowledge of it, but it makes sense considering the Hutch mod removes air from the system...
2002 F250 CCSB 4x4
PHP Phoenix, John Woods VB, NUC bypass, 6637
"No country can be called free which is governed by an absolute power;
and it matters not whether it be an absolute royal power or an absolute
legislative power, as the consequences will be the same to the people."
--Thomas Paine, Four Letters on Interesting Subjects, 1776
Macon is offline
post #3 of 9 Old 11-06-2013, 08:18 PM
Joel's Avatar
Quoted: 10 Post(s)
That's the general consensus around here
Heck of a lot cheaper to do the hutch.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
post #4 of 9 Old 11-06-2013, 08:23 PM
Macon's Avatar
I negated to mention that Air Dog / FASS were on my list of upgrades. The more I read, the more I learned...meh. A good pump does what's needed, with the Hutch mod. A quality prefilter is not a bad thing though.
2002 F250 CCSB 4x4
Macon is offline
post #5 of 9 Old 11-07-2013, 07:58 AM Thread Starter
But what's the difference between the 150 and 165 I don't won't to do the hutch mod.
honda144 is offline
post #6 of 9 Old 11-07-2013, 06:01 PM
03ranger30's Avatar
Less than $50 bucks on some fuel lines or over $500 on an AirDog....doesn't make much sense.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #7 of 9 Old 11-07-2013, 06:15 PM
Macon's Avatar
One feeds the factory pump, the other bypasses it.
2002 F250 CCSB 4x4
Macon is offline
post #8 of 9 Old 11-08-2013, 09:51 PM
DeputyDiesel's Avatar
Dont buy the Raptor unless you enjoy swapping out pumps and waiting for warranty.
2003 F350 DRW 7.3 6 speed. 4 inch lift, 35x12.50's Goodyear Dura Trac all around, steel 2 inch dually spacer rear. southbend clutch, Dp tuner high idle 60t 80 econ 120 race 140 extreme, afe stage2 intake, pdr super gtp turbo, pdr up pipes, non ebpv pedestal, DIY regulated return, fuel bowl delete, in tank mods, pac brake pxrb,6.0L Intercooler, Terminator T500 HPOP, 6 inch miter cut stacks . KW mud flaps w/custom mounts.
06 F350 CC LB
DeputyDiesel is offline
post #9 of 9 Old 11-22-2013, 04:15 PM
Seth14's Avatar
Yes! I believe the 165 is a stand alone pump set at a high psi, I have the 150 that feeds my factory pump at like 8-10psi. Absolutely no issue with mine yet....only 10 months on it tho.
Late 99, Blackwater long block, forged rods, ARP studs, 910 comp valve springs, stelite valves, 38R turbo, 238/100 hybrids, TS 6 position chip custom tuned by Beans, T500 hpop, FRx, Airdog 150, S&B intake, side piped, edge insight cts monitor, DC2 rims, Crusher tires, BTS transmission, 6.0 31 row tranny cooler, and lots of blue lights!!!!
Seth14 is offline
