mounting pyrometer gauge - Ford Powerstroke Diesel Forum
post #1 of 17 Old 11-04-2013, 06:04 PM Thread Starter
SUPERDUALLY350's Avatar
what are the pros can cons of mounting the pyrometer gauges befor or after the turbo?
SUPERDUALLY350 is offline
post #2 of 17 Old 11-04-2013, 06:07 PM
zdawg8394's Avatar
before, you know the temperature going into the turbo... after the turbo you know how hot your exhaust pipes are. You need pyro to watch the temperature of the exhaust running through the turbo so... put it before.
08 F350 6.4 4x4 Lariat CCSB
-BDS 4 inch radius lift - Fox 2.0 shocks - XD monster 20x10 chrome rims - Toyo open country m/t 37/13.50/r20 - Procomp dual steering stabilizer w/fox stabilizers - 2wd valance - HID heads and fogs - escort 8500 x50 blendmounted - CTS insight with dash pod - interior led conversion
"When you nail the throttle in traffic trying to get around someone chr*st I think GM could have mailed me that 400hp faster then I got it out of the truck."
zdawg8394 is offline
post #3 of 17 Old 11-04-2013, 06:28 PM Thread Starter
k thats what i thought but the instructions say after i was confussed why youd want it there
post #4 of 17 Old 11-04-2013, 06:34 PM
zdawg8394's Avatar
Glowshift?
post #5 of 17 Old 11-04-2013, 06:35 PM Thread Starter
Glowshift?
yep i went with the tow max gauges
post #6 of 17 Old 11-04-2013, 06:37 PM
zdawg8394's Avatar
I think i have heard those say that in the instructions... don't know why. but I would def. put it pre turbo.
post #7 of 17 Old 11-04-2013, 06:38 PM Thread Starter
yeah and i kept hearing pre turbo so i just figured id post a quick thread. thanks for the info
post #8 of 17 Old 11-04-2013, 06:40 PM
zdawg8394's Avatar
no problem, wait around and see if anyone else says anything... maybe someone knows why they say put it after?
post #9 of 17 Old 11-04-2013, 06:48 PM
CSIPSD's Avatar
After?
So you know what caused your motor to blow when you run 1300* POST turbo rather then pre-turbo.
There is NOT ONE SINGLE reason to run a pyro post turbo.
And FYI, your not watching egt's for the turbo, the turbo can see temps in excess of 2000* for 30 minutes without damage...
Your pistons will melt at over 1400* for 2 minutes.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #10 of 17 Old 11-04-2013, 06:50 PM
PowerStrokedRedneck's Avatar
Pre-Turbo gives a more accurate temp of what the cylnders are at. The gauge will be alot more alive and move more due to the temp changes. And you'll see hotter temps However should that probe failed (ive seen it happen), you get to replace your turbo too.
Post-Turbo the gauge will act more lazy and be slower to react due to the turbo taking some of the heat. For that reason your temp will be lower. Every semi-truck on the road that has a pyro will be Post-Turbo.
Both ways are accptable, as long as you know what your looking at. I do know that 1100* is absolute max you would ever want to see after the turbo. After that the turbo fins will glow and warp. I personal have mine after the turbo, and that is the only way I'll do it, unless I put one in each manifold.
PowerStrokedRedneck is offline
