problems after upgrades - Ford Powerstroke Diesel Forum
post #1 of 26 Old 11-04-2013, 05:23 PM Thread Starter
dirtboy33's Avatar
A buddy Installed 4" exhaust afe intake and a edge evolution programmer on his 2002 automatic f250. Everyrhing works great except when under full throttle the truck shifts into over drive he gets a big whoshing sound and boost goes from 20lbs to about 6-8lbs and he can't get over 70mph. No check engine light. Let off the throttle then floor it again boost picks up and truck takes off again. Anyone ever had this problem?
2002 F-250 7.3L 6 speed, 4" turbo back straight pipe, spectre intake w/ brute force dry filter, XDP compressor wheel, DIY boost fooler, PHP FU, oil HPX, ccv dumped, ebpv delete, unplugged waste gate, zoodad mod, AIH delete, 6.0 intercooler swap, triple pillar pod guage, 2.5" leveling kit, 315/75/16 BFG KM2 Krawlers
dirtboy33 is offline
post #2 of 26 Old 11-04-2013, 05:33 PM
CSIPSD's Avatar
Sounds like turbo surge... Or stall and then surge.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #3 of 26 Old 11-04-2013, 06:30 PM
heisman01's Avatar
Quoted: 52 Post(s)
edges aren't the best tuner either especially for the transmission, could be a defueling or TQ issue if it only happens at WOT going 70+
DD- 11 6.7 scsb: sct4 gearhead tunes, 4" dpb axle dump exhaust, 2.5 level, fox shocks, no limit egr delete, no limit stage 2 intake, STT PRO 295/65r20, black fuel couplers
sold- 00 7.3 modded to the end.
heisman01 is offline
post #4 of 26 Old 11-05-2013, 01:05 PM Thread Starter
dirtboy33's Avatar
Tried unplugging the waste gate. Made it better but still not fixed. Would it derate with no cel? When it happens nothing seams out of the ordinary. Its like he just eases off the throttle when it shifts into ove drive. But left off anr floor it again and takes right off
post #5 of 26 Old 11-05-2013, 01:09 PM
Get a pro tune ASAP
AWDsome08 is offline
post #6 of 26 Old 11-05-2013, 01:58 PM Thread Starter
dirtboy33's Avatar
Got another buddy have the same exact issue except his truck has no tunes and is straight drive. Intake and straight pipe
post #7 of 26 Old 11-05-2013, 02:46 PM
might be...
Might wanna check out your intake and intercooler piping along with all couplers. Sometimes when more boost is added things like the intake hoses and couplers suffer and a small leak is formed. I know this was what happened to me when I had my 560whp Subaru.
post #8 of 26 Old 11-05-2013, 03:03 PM
luke7.3's Avatar
Quoted: 24 Post(s)
Tell him to unplug the edge. If it does the same you can narrow it down to intake.
Luke
97 F250 CCSB 4 inch straight pipe, 6637 intake, TS 6 pos (daily)
08 F350 6.4 Reg Cab flatbed Spartan tuned, AFE Intake, DPF/DOC Delete(work truck)
luke7.3 is offline
post #9 of 26 Old 11-05-2013, 03:13 PM Thread Starter
dirtboy33's Avatar
Ok. Now on the other truck with no tunes. It doesn't do it all the time. No ryme or reason might go days withough doing it.
post #10 of 26 Old 11-05-2013, 04:19 PM
the other truck...
What is the year of the other truck? Might be the MAF sensir needing to be cleaned or it might be fuel pump or filter. Clean your MAF firstand give it a week. See if the issues go away. If not, clean your fuel filter and do the same, wait... ect.
