Fuel Tank Options - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-01-2013, 10:25 PM Thread Starter
Shaolin Crane's Avatar
Fuel Tank Options
So I have a new to me 2000 F250 CCSB. This being my first shortbed truck I am not use to the small fuel tank. And since all the oversized fuel tank options are stupid expensive, what are my OEM options for switching tanks? Is it possible to use a tank from a long bed truck? Or am I limited to what the aftermarket gives me?
Too many vehicles to keep up with.
Shaolin Crane is offline
post #2 of 13 Old 11-02-2013, 05:19 AM
Quoted: 16 Post(s)
Feedback Score: 3 reviews
I'm not sure on long bed tank but i have read that some add an excursion tank(50gal). It fits where the spare tire goes.
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 13 Old 11-02-2013, 01:51 PM Thread Starter
I'm not going to give up my spare, would be just as much of a headache as my 26 gallon tank.
post #4 of 13 Old 11-02-2013, 03:05 PM
Quoted: 16 Post(s)
i agree but that is the only other option i have read about. i have learned to live with the 29 gallon tank. the hutch mod will help get the last 3 or 4 gallons in
post #5 of 13 Old 11-02-2013, 03:32 PM Thread Starter
Doesn't matter what I do, I can't get more than 26 gallons in. It's been ran dry twice now. Once the low fuel light comes on I have about 5 minutes before it's completely empty.
Anyone else?
post #6 of 13 Old 11-04-2013, 09:59 AM
CSIPSD's Avatar
What do you do with your bed? Already being a short bed doesnt help, but I run a 110 gallon L tank in my bed, plumbed into the main tank...
1500-1800 miles between fill ups if I like.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #7 of 13 Old 11-04-2013, 02:30 PM
Quoted: 27 Post(s)
haha, just for sh*ts and giggles, whats it cost ya to fill up if your on E?
I believe the only options are either the Excursion tank or some kind of in bed tank.
FWIW, a spare tire takes up less room than an auxiliary tank would in your bed. In the end it up to you but i have had my spare tire in my bed since i bought the truck, if i need my bed space i put the spare in the extracab, hasnt bothered me.
2000 F-250 XCLB 4x4 6 Speed, PIS 175/80's, ARP's, 910's, Irate Fuel, 6637, GTP38R, 4" turbo back, Hydra PHP tuned, International Up-pipes, ISSPRO Boost, EGT, HPOP and Fuel Pressure gauges. SB Clutch. MB Diesel HPOP stage 2.
CarportMechanic is offline
post #8 of 13 Old 11-04-2013, 03:00 PM
Anyone else?
You aren't filling it all the way. The TOP 4 gallons happens after the filling nozzle first clicks off as though it was full. You can then put four more gallons in so long as you reduce the flow rate of the nozzle. I have a stock tank on my shortbed, no hutch or harpoon mods, and the extra four gallons makes a big difference on long trips towing.
As an experiment next time you fill up, let the nozzle click off as though it were full. You can then trickle in the next 4 gallons, actually 4.5 if you're feeling lucky, but go slow and watch the foam. Keep an eye on the filler neck so that you don't overflow.
2000 F350 4wd CC SB PSD
Normal mods plus gauges and PHP chip
Lowered to F250 height
Stock tire size, looks stock.
18' 10k# equipment trailer
30' Travel Trailer 7500#
Kioti CK30 tractor
Kawasaki KLX250s Dual Sport
Highbeam is offline
post #9 of 13 Old 11-04-2013, 03:15 PM
CSIPSD's Avatar
This was only the X tank...
Joe
CSIPSD is offline
post #10 of 13 Old 11-04-2013, 04:22 PM
Joel's Avatar
Quoted: 10 Post(s)
I don't haul my spare tire around town. Only when I go out of town and hunting and stuff like that.
I have an excursion tank waiting to install. Just can't decide how to plumb it in.
PIS 230/80's, Van Turbo with EBPV, BD Billet Wheel
Lots of money spent at RiffRaff
Dual SD fuel pumps, in tank mods, CNC Fab bowl retain kit. SDK Tunes. Isspro.
Still pretty slow, just less slow now.
Originally Posted by peixinho View Post
I love finally having my truck back... that 7.3 dog that I was driving was just not cutting it.
Joel is offline
