Airbag helper spring recommendations - Ford Powerstroke Diesel Forum
post #1 of 9 Old 10-25-2013, 09:38 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I'm thinking it's time for a set of air bags for my truck, my leafs are getting tired after 170k. I don't tow much, but have a WVO set up and carry about 350 pounds when the tank is full, and I always keep the tank 1/2 to full. I take a few mountain bike trips a year and load up with a rear mount bike rack that can hold 6 bikes and the back is full with camping gear, firewood, and about 500 pounds of WVO. My leaf springs get bottomed out on the bumpers. I added an add-a-leaf a few years ago, but it hasn't helped a ton.
What recommendations does everyone have for brand and model of air bags? I have been trying to research it, but figured I'd ask what people are using. Some mount to the axle, some to the top of the leaf springs/axle U Bolts. Any advantage to one over the other? I've drilled into the frame before and it's not easy. If there is a no drill model out there that bolts right on that would be a plus. I was looking at the Firestone Ride-Rite 2550
Ford F350 1999-2004 Air Bag Helper Springs by Firestone #2550 | SuspensionConnection.com
and the images on various websites show the 2550 differently, so I'm not sure where they actually mount or if they are in fact "No Drill". Any recommendations?
2000 F350 Crew Cab Short Bed,
AIS Intake/Zoodad, 203 thermostat, Billet Housing
Vegistroke WVO conversion, AIH Delete, Wicked Wheel, TurboMaster Wastegate controller
Pyro/Boost/Tranny Guages
4" Magnaflow Straight Pipe
DP-Tuner F6 80hp Econo, 80hp Tow, Decel, 100hp Performance, 120hp Race
BioStroker is offline
post #2 of 9 Old 10-25-2013, 10:13 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 12 Post(s)
Feedback Score: 12 reviews
I clicked your link. It clearly says in caps NO DRILLING lol. I too would like to add airbags, and since I already have a tank and compressor mounted I'm already half way there! Hopefully well get some good input from a few members.
Sent from AutoGuide.com App
2017 f250 platinum
Bone stock until warranty expires!
mts678 is offline
post #3 of 9 Old 10-25-2013, 10:29 PM
I am running firestone ride rite on my truck, the 5000lb bags, they were very easy to install, and they set above the axle, not the springs. I too already had a tank and compressor on my truck, so I bought a gauge with dump valve, mounted to the dash and tee'd into my on board air. ( Train Horn tank ) I have a F-250 3/4 ton single cab, which I built for pulling a 38ft toy hauler trailer, the trailer dry weight is 14,500lb, and I haven't had any issues with the bags. The truck sets level with the trailer attached and 85psi in the bags.
Hope this helps,
CBly
Cbly is offline
post #4 of 9 Old 10-26-2013, 02:51 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
I saw that they claim "no drilling", but when I did a Google search for "Firestone Ride Rite 2550" other sites say drilling is required. So, not sure which is accurate. I would like to hear from someone first hand who has this exact kit! There are a bunch of options and I just don't know enough about them to figure out which ones to buy.
post #5 of 9 Old 10-26-2013, 02:53 PM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Hope this helps,
CBly
Thanks for the info. Do you happen to know the exact model number you have? Did you have to drill into your frame, or did it use existing holes?
post #6 of 9 Old 10-26-2013, 11:14 PM
Model 2550, and I don't recall having to do any drilling on the frame, I installed them the same time as my B&W turn over ball, and I did have to drill on the frame to install the turn over ball , but not the air bags, .....
Have had them on for better than 2yrs with no complaints.
Update, I just clicked on the link that the OP listed, the picture that is showing is for a 2003 thru 2004, I had a 2003 6.0 and that was the style mounting bracket that I had to use, If I remember correctly, the springs on the 2003 set out side the frame rails just a bit and therefore the airbag rode directly on top of the spring pack. MY 2002 7.3l the springs set directly underneath the frame, and the airbag sets above the axle on the inside of the springs. So the pic you posted wont be the ones for the earlier mode l trucks. The 2003 kit did involve some modifications to the frame and bracket, due to my fifth wheel hitch plates.
CBly
Cbly is offline
post #7 of 9 Old 10-27-2013, 10:54 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Thanks, that's helpful information. I did notice the picture on the link I posted in the original post says something like, "may not be exact image of product," so who knows how the 2550 kit mounts since the image might not even be for that product.
post #8 of 9 Old 10-27-2013, 01:57 PM
LFD132's Avatar
Quoted: 3 Post(s)
Good info...I'm looking at the ride rite 2535 for my 2013. I guess my only concern would be a bag popping and maybe losing control from the sudden weight shift.
[SIGPIC][SIGPIC]2013 F250 FX4
LFD132 is offline
post #9 of 9 Old 10-28-2013, 05:22 AM Thread Starter
BioStroker's Avatar
Quoted: 4 Post(s)
Monday am bump. Any 7.3 guys out there with some advice?
Also found these:
http://www.amazon.com/gp/aw/d/B00017YYIG/ref=mp_s_a_1_3?qid=1382416595&sr=8-3&pi=AC_SX110_SY165_QL70
Anyone have experience with the Air Lift brand helper air bags?
