Does my 7.3 have to many miles to do mods? - Ford Powerstroke Diesel Forum
post #1 of 20 Old 10-24-2013, 09:39 PM Thread Starter
MEJIA's Avatar
I'm new to the diesel world, not to long ago i got an all stock 2002 F250 7.3L with 220,000 ( needed it for work and got it by doing a car trade, so i thought it was a good deal!) According to my neighbor who happens to be a mechanic if I do mods i would be doing more harm than good. That if I did mods I would shorten the life and probably would only be able to add a max of 80,000 miles on it. I was hoping to do a 6637 intake mod, ccv mod, get a 5" exhaust with 6" tip, and maybe a dp tuner. My dad has a 2001 7.3 f350 nearly all stock and has gotten 500,000+ miles on it, so i was hoping I could get a second opinion on it, what do you guys think?
MEJIA is offline
post #2 of 20 Old 10-24-2013, 09:43 PM
usteffenhagen's Avatar
I can't see how opening up the intake and exhaust could be a bad thing???
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 20 Old 10-24-2013, 09:44 PM
oh and
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 20 Old 10-24-2013, 10:02 PM
Rodslinger's B1TCH
I don't think it's the mods that kill, it's the driver.
when the truck stays stock there isn't much excitement to flooring the go pedal on a regular basis but when you start modding it you feel the need drive it like you stole it more often to see what kind of difference the mods make to it.
that being said, intake and exhaust are a good idea and the bigger exhaust will most likely pro-long the life of the engine. the tuner isn't a bad idea if it stays on a low setting that will give you a slightly firmer shift and a little extra power. it's the track day style driving that will kill it.
steve604 is offline
post #5 of 20 Old 10-24-2013, 10:07 PM Thread Starter
MEJIA's Avatar
Thanks! and that is exactly what i thought, he stated those things would be putting too much work on the engine, and there's a risk that doing that intake could ruin my piston rings, i was really confused on how that could happen, but apparently he has seen that happen with diesel mods
MEJIA is offline
post #6 of 20 Old 10-24-2013, 10:13 PM
Yeah maybe idiots using their programmer on extreme all the time lol
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #7 of 20 Old 10-24-2013, 10:15 PM Thread Starter
MEJIA's Avatar
Haha seems logical, I say I'm a calm easy driver but that's probably because im all stock!
I have another ? then, is there any other mods on top of the intake and exhaust that are good start mods that benefit truck like towing, or mpg?
I drive it 6 days a week on a set schedule and haul a cattle trailer 3 days out of the week
MEJIA is offline
post #8 of 20 Old 10-24-2013, 10:19 PM
You can get a 6 position chip with different HP settings for in town, towing, economy etc.. I don't use mine it came with the truck. I only use high idle lol. Until I get it re burned though...
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #9 of 20 Old 10-25-2013, 06:34 AM
03ranger30's Avatar
The trans is what I would be worried about.
Charlie
2003 F250 CCSB 7.3--Gearhead tuned, MBRP 5", 6637, Diesel Site Coolant Filter, 203* Thermostat, ISSPROs, HPx, 5% tint
03ranger30 is offline
post #10 of 20 Old 10-25-2013, 07:23 AM
Quoted: 724 Post(s)
All the things listed will help your truck, not hurt it. Even the chip will help on tow/economy tunes. Hauling cattle 3 times a week, you really need to get a trans cooler out of a 6.0L, and seriously look at getting a BTS or John Wood valve body at the very least.
Do yourself a huge favor and get hooked up with Matt Robinson. Owner of Gearhead Performance. He lives in Bryan TX too. Since he's so close, I would pass on the DP tuner. Not that DP is bad, but more so Gearhead tunes are also just as good, and he's your neighbor. :thumbup:
Corey@CNCFAB is online now
