Gauges installed, question... - Ford Powerstroke Diesel Forum
post #1 of 17 Old 10-24-2013, 05:48 PM Thread Starter
Installed triple Gauge pod from diesel manor, everything works great except the transaction oil temp is slow, very slow to come up. Is that normal?
barko is offline
post #2 of 17 Old 10-24-2013, 06:17 PM
My transmission oil temperature takes longer to come up than the other parameters that I monitor.
I suspect it is due to it being farther from the combustion part of the engine which is generating heat quickly, and that its heat comes from the fluid friction inside the transmission itself which will take longer to heat the large mass of metal the transmission is made of.
This is what I think.
2007 F-350 W/Lariat package
4x4 6.0l diesel engine
Leveling kit and 35 inch tires
Coolant Filter kit
EGR Delete Kit
Glowshift Gauge Pillar Pod (EGT, Trans Temp, Fuel Pressure and Coolant Pressure)
Fuel System Blue Spring Upgrade
SCT Tuner
Diamond Eye 4" stainless steel turbo back exhaust kit
ScanGuage II
Zoodad Mod
Backup Cameras from Tadibrothers.com for both truck and 25' Travel Trailer
DJGut is offline
post #3 of 17 Old 10-24-2013, 06:26 PM
CSIPSD's Avatar
Sounds normal.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #4 of 17 Old 10-24-2013, 07:13 PM Thread Starter
And it only topped out around 140 degrees!
barko is offline
post #5 of 17 Old 10-24-2013, 07:19 PM
how long did it take to get to that temp? and what kind of driving were you doing?
Wizard13 is offline
post #6 of 17 Old 10-24-2013, 07:27 PM
hansel's Avatar
Quoted: 95 Post(s)
Mine takes a few minutes too get over 100* and now that the temps outside are in the 40's too 50's my tranny temp doesn't get over 100*. I do have a 6.0L cooler
2001 7.3L CCSRW 4X4
Airiad Intake 4" Flo-Pro Exhaust
ISSPRO EGT/Transmission
PHP Hydra
2015 Heartland Prowler
hansel is offline
post #7 of 17 Old 10-25-2013, 10:48 AM
Justin@DP-Tuner's Avatar
Quoted: 51 Post(s)
Completely normal... 140* is a nice cool temperature to top out at. No worries there.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #8 of 17 Old 10-25-2013, 11:24 AM
CSIPSD's Avatar
Keep in mind there is also too COLD... You do not want to be driving around all day with the trans at 100* or below.
That will cause issues just as much as too hot.
Joe
CSIPSD is offline
post #9 of 17 Old 10-25-2013, 06:44 PM
hansel's Avatar
Quoted: 95 Post(s)
Mark K over at Diesel stop forum said the temps I'm running with the 6.0L cooler are fine, even below 100*. The only time he said too get concerned is in the 230*+ range.
2001 7.3L CCSRW 4X4
PHP Hydra
hansel is offline
post #10 of 17 Old 10-25-2013, 06:59 PM
jesilvas's Avatar
Quoted: 2 Post(s)
It does need to be somewhat warm. Somewhere under 100*F the TC will not lock, in order to produce more heat.
4R100, 2wd
330,000 + miles
jesilvas is offline
