P1211 code gone? - Ford Powerstroke Diesel Forum
post #1 of 2 Old 10-20-2013, 01:59 PM Thread Starter
P1211 code gone?
Just looking for an explanation....if there is one. The wife and I are on an extended trip with our fifth wheel. Just before leaving I did all the usual maintenance on my truck. When I changed the oil I went with Valvoline Premium Blue Dino oil...it was on sale at Napa. I had never used it before. Anyway, with the PHP tuner set for 40hp tow we set out and within thirty miles I had thrown a P1211 code. I reset it and drove on, again the code set. No matter what, if I drove in 40hp or 65hp tow mode the truck would throw that code within a few miles. I dropped to 25hp tow mode and that solved the issue....The concensus on this forum was that I probably had a weak HPOP, which made sense. We went about 3500 miles before I had my oil changed. I decided to switch back to Rotella T Dino. Since that oil change we've driven a little over 2000 miles. I've had the tuner set on 40hp tow and even used the 65hp tow several times driving the flats and haven't thrown a code. Does this make sense to anyone? Can an HPOP be finicky when it comes to oil types or the addidtive packages they use? Just curious.
Thanks and regards
2000 F350 7.3 4X4 SRW, SC, LB, VDO Gauges, JWVB, PHP Hydra, Tru-Cool Max, KYB Monomax, BTM, BD Brakeloc, S&B CAI, zoodad, WW, Firestone Airbags
cpfullback is offline
post #2 of 2 Old 10-21-2013, 02:26 PM Thread Starter
The underwhelming response would indicate that no one has seen such symptom change by simply changing the type of oil being used? We've driven another 700 miles sice I wrote thise, hard towing miles, steep grades and all in the 40hp tow tune. Not a single code. I guess it gets logged in my WTF column...just won't stick VPB oil back in my truck, apparently there is something in that oils forumla that my truck doesn't like.
