Better fuel filtration - Ford Powerstroke Diesel Forum
post #1 of 21 Old 07-15-2008, 09:37 AM Thread Starter
Quoted: 17 Post(s)
Send a message via AIM to rufushusky
Hey all,
Anyone know what the stock Ford fuel filter is rated at? Also is there an easy way to add a spin on fuel filter to a 2000 7.3??
Thanks!
2002 F-350 4X4 ECLB 7.3 4R100 6637 filter w/ RiffRaff cover, 08 diff cover, 203* T-stat, HPX, Stancor Relay, 6.0 trans cooler, Zone leveling kit, 8'6" Western Ultramount
Sold: 04.5 Dodge Ram 2500 5.9 CTD, Reg Cab, 48re
rufushusky is offline
post #2 of 21 Old 07-15-2008, 09:52 AM
tubular031's Avatar
I put one of ITPs kits on my truck and its much quiter and you also add a filter on the rail
ITP 7.3L Fuel Tank / Pre-Pump Kit
or you can DIY it like Guzzy did
Welcome to guzzle's In-tank Hutch Mod Web Page
My stock fuel lines had a break in them to add a filter i would guess. The break in the line was right under the rear drivers door. you could add one there with out having to do all the other tank stuff.
Just a basic 01 F350 CCLB SRW -Good from a far but far from good
tubular031 is offline
post #3 of 21 Old 07-15-2008, 10:30 AM
00strker's Avatar
i would think it would be very easy 2 put a in line fuel filter system in like tubular did
2000 7.3 Few mods...SOLD
2003 Common Rail tow rig / DD
2006 Harley edition F-250.. 10in Fab, 24in Rockstars, 38x14 Kuhmos, 4in MBRP, Gearhead tunes...NO STUDS
00strker is offline
post #4 of 21 Old 07-15-2008, 10:37 AM Thread Starter
Quoted: 17 Post(s)
Yeah I threw a cat filter inline with my truck, I just did not know if there were any quirks to the Ford system, I know you guys have higher pressure from your lift pump.
post #5 of 21 Old 07-16-2008, 10:41 PM
Send a message via Yahoo to snakyjake
I wonder if adding an in-line filter would cause problems with the stock fuel pump or other fuel flow issues? Would it cause a premature fuel pump failure?
What is deficient about the stock fuel filter?
snakyjake is offline
post #6 of 21 Old 07-17-2008, 05:22 AM
tubular031's Avatar
Well many of us out there have added a filter before the pump either when doing the intank mods or just adding it, So far I have not read about anyone saying their pump died because of this. I added mine because after reading about the stock pickup and all the air in the system, it sounded like a good idea. Now that its installed, I am VERY happy with it! My truck is much quieter now! Plus I can change the one on the rail for about 10 or 11 bucks and the engine one costs 30 something. The one on the rail also has a water drain incase any water makes its way in the tank. so now I have 2 filters protecting my expensive injectors rather then 1.
post #7 of 21 Old 07-17-2008, 06:33 AM Thread Starter
Quoted: 17 Post(s)
Nothing is necessarily wrong with the stock filter but sometimes I just want a little more protection you know? Especially with the cost of HEUI injectors. I rarely hear of PSDs losing lift pumps, they are pretty beast pumps for stock LPs.
post #8 of 21 Old 07-17-2008, 10:31 AM
CSIPSD's Avatar
Stock only filters to 10 mic... My pre pump is 10 mic and post pump is 2 mic...
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #9 of 21 Old 07-17-2008, 10:33 AM Thread Starter
Quoted: 17 Post(s)
Do you have the swamps set up?
Like this?
post #10 of 21 Old 07-17-2008, 10:38 AM
John Wood Nut Swinger
strokin_early_99's Avatar
Here is mine. I have a 12 micron pre pump and 2 micron post pump:
(Born on 11-20-98) F350 CC LWB 4X4
north of 480hp and south of 13.7sec
Bored with current setup
Family of 5 saved by Grace.....
Sponsored by Left Coast Diesel in Concord, Ca
Anything BUT Conservative Performance
strokin_early_99 is offline
