T500 vs Tunes? - Ford Powerstroke Diesel Forum
post #1 of 15 Old 10-17-2013, 03:35 PM Thread Starter
03machstock's Avatar
T500 vs Tunes?
Hey guys, I have been wanting to order tunes here for a while and I was getting ready to pull the trigger but I was wondering, would it be worth it to get an hpop like the t500 for my e99 before i got tunes to make it more beneficial? I plan eventually on doing hpop, injectors, turbo, ect... but for the next couple years, i was just going to run exhaust/intake/tunes; that is, unless there is a huge benefit adding a t500 before i do tunes. For now, im just looking for a solid/ strong /reliable running truck, not looking to win races or put up numbers.
Thanks,
Dan
e99 F-250 Regular cab lariat 4x4 manual transfer case, 6 speed 7.3
Warn Premium Hubs
Isspro ev2 Pyro and Boost
6637
MBRP 4" with muffler
Rigid D2's
03machstock is offline
post #2 of 15 Old 10-17-2013, 04:01 PM
Justin@DP-Tuner's Avatar
Quoted: 66 Post(s)
Best way to tell if you need one would be to do a WOT run in OD from 60-90mph. You will need to have a scan tool hooked up that can monitor ICP and IPR duty cycle. You will want to watch where ICP levels out at and what your IPR duty cycle is. A low ICP and high duty cycle would be an indication that you could benefit from a better HPOP.
However, adding a T500 is never a bad idea anyway.
DP-Tuner
For Your Tuning Needs
Like us on
Justin Bochmann
Sales and Technical Support
828-221-0076 ext.804
Justin@DP-Tuner is offline
post #3 of 15 Old 10-17-2013, 05:52 PM
79 toy's Avatar
Can an edge cts monitor those ?
79 toy is offline
post #4 of 15 Old 10-18-2013, 09:51 AM
Quoted: 66 Post(s)
Should be able to. You may want to check with Edge first though.
DP-Tuner
Like us on
Justin Bochmann
post #5 of 15 Old 10-18-2013, 09:59 AM
blue99stroker's Avatar
Quoted: 289 Post(s)
id get a chip first.
my friend doesnt have any issues with his e99 so as long your hpop is healthy you are fine.
99.5 f250 7.3 4x4 265k Full Force 160/30, PHP Hydra, S&B CAI, 4" Exhaust, Van Turbo, RR 6/6 Billet Wheel, Autometer Gauges, Transgo Tugger/sonnax shift kits, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool Max.
Dad-2000 F250 7.3 4x4 114k Autometer Gauges, Superchips 1705 (Tow Safe), Blue 6637, 4" Exhaust, BD Billet Wheel, Trucool Max.
blue99stroker is offline
post #6 of 15 Old 10-18-2013, 10:19 AM
Ford7three's Avatar
An HPOP on any 7.3L is a good idea, weak or not there are benefits. Once you go to a tuner the hpop will be even more noticeable.
Ford7three is offline
post #7 of 15 Old 10-18-2013, 11:54 AM
CSIPSD's Avatar
LOL... I've made more HP than 90% of the people in the 7.3 forum... of a stock 250k 17* hpop.
If its a healthy pump, get a chip and enjoy... I'm not one for replacing parts that are working.
As well if you're going to do a HPOP, there are better options available.
01 F-250 SC PSD,320k,16 Isspro Gauges, AFE-2,CCV Mod,IAH delete,map reg,Modded H2e, 6.0 IC, 230/100 from P.I.S, Studs, 910 springs, Forged rods, Water injection,Hydra chip-No Limit/Gearhead tuning, Swamps HVHF IDM, MBRP 4" dual's, Aero, 6" tip's, 4" Revtek lift, 37/12.5/16.5 MT's
Joe
DYNOPROVEN.COM, PERFORMANCEINJECTIONSYSTEMS.COM and RIFFRAFFDIESEL.COM
CSIPSD is offline
post #8 of 15 Old 10-18-2013, 12:17 PM
I have been running PHP tunes for 3yrs now. My stock HPOP does fine except for full throttle or towing heavy. I will throw a low icp code after about 15 seconds of full throttle or going up long, steep grades. Replacing it would be nice and I am sure there would be a decent power increase, however I can't justify the cost for a little bit of performance.
2014 F150 SCREW XLT 4x4 Ecoboost.
blderman is offline
post #9 of 15 Old 10-18-2013, 12:49 PM
Just imagine how much more power you could have made if you had a decent HPOP.
The T-500 is a great option if you decide to upgrade. You won't be disappointed.
Eramojo is offline
post #10 of 15 Old 10-18-2013, 01:11 PM
CSIPSD's Avatar
ICP pressures and duty cycles were right where my tuner requested them, so... I would not have made more...
Thats what some of you bandwagon people don't get...
So one post, registering today, got to be someone hiding behind a user name...
Joe
CSIPSD is offline
