Irate r/r fass pump prime problems - Ford Powerstroke Diesel Forum
post #1 of 6 Old 10-15-2013, 07:42 PM Thread Starter
Ok I recently went overboard with upgrades, motor is back together with 238/100s and I installed the irate regulated return with the fuel lab regulator. Prior to upgrades I had a fass 125 gph "titanium" pre/post pump with filter and seperator.
The truck is an early 99 and I'm not sure if that mattered but I was told the kit mounts the regulator quite nicely (it doesnt come close to anything in my application to bolt to). I've got the passenger side head going into one side of the regulator, driver side in the other, and my 3/8 ID line coming off the bottom which I tied into the existing factory hard line under driver door on the frame rail. My supply is coming from the pump, brand new line 1/2 ID.
I had no clue where to start with the adjustment on top of the regulator so I put it in to where half the threads are showing..unsure what the brass fitting with Allen head on the side does, vacuum? It's just plugged now.
Problem: when I attempt to prime it up and cycle the pump a bunch to adjust the return pressure I can't get a damn thing. The pump does work. If I crack a line on either side of the regulator (either input from cylinder head) the pump starts to do its job and fuel sprays out everywhere. I cannot get anything to come out the return side of the regulator whether the adjustment on top is all the way in, or totally removed . Im sure there is a stupid mistake somewhere and if you need pictures please say and I will supply. Over 40 hours in upgrades and now can't hear it run really is upsetting
Tarpontwo is offline
post #2 of 6 Old 10-16-2013, 03:07 AM
Quoted: 17 Post(s)
Feedback Score: 3 reviews
I'm pretty sure the truck will need to be running in order to adjust the reg. Where is your gauge installed?
2000 F250 XcabSB, 4x4, 4" strait pipe, DIY intake, FRx, BDP tunes, WW2, 6.0 cooler, BTS VB, gauges, 55w digital projector HIDs
gomer pyle is offline
post #3 of 6 Old 10-16-2013, 04:09 AM Thread Starter
The gauge is installed on the regulator at the moment
post #4 of 6 Old 10-16-2013, 08:03 AM
I just went through this on my 01. As long as you have no air leaks on the suction side you will be able to see pressure on the gauge with the pump on engine off. I forgot to tighten my pickup tube which sucked a bunch of air in and i couldnt get anything on the gauge.
I would check you suction side for leaks.
The port on the right side of the regulator is a boost reference port and is not used. You should route a line from that port to the bottom of the motor incase the diaphragm ever fails in the regulator.
Greenman01 is offline
post #5 of 6 Old 10-16-2013, 09:43 AM
Ford7three's Avatar
On my Irate kit I just cracked a line till it was running and had someone underhood adjust my pressure since I have an in cab gauge instead of the one that is provided in the kit. It should be constantly returning if not something is not right. I have my boost port plugged as well.
Ford7three is offline
post #6 of 6 Old 10-18-2013, 08:56 PM
the1laf's Avatar
On my RR once I primed my pump and filters everything worked great, I installed a T fitting so I have an fuel pressure gauge inside the cab as well as the provided one for adjustment.
I'd just put the top adjustment screw hand snug until you get a steady pressure, I tightened mine most of the way down like you did and it just about pegged the 100psi gauge before I could turn it down once i got fuel.
I'd also check to make sure your pump is primed right, any air lock and the pump can't do it's job. (Unscrew both filters and individually fill them did it for me)
2000 F-350 Lariat CCLB w. 335,000+ Mi
Tymar intake, Straight 4", 6.0 Intercooler, IDP Competition Fuel System, AC's, SB SD Clutch, ZF6 Short Shift Kit
Gearhead Tunes, Swamps IDM, Snow Performance Water/Meth, Isspro Performax Gauges & 08 Black Leather Seats
05 Harley's, Smoked tails, Weld Racing Sidewinder Wheels
Fried Piston, Re-building engine
330 RWHP Fuel Only - 363 RWHP w. Meth
Broke College kid... Eating Ramon to save for truck parts..
the1laf is offline
