Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 07-11-2008, 05:39 PM
siloped siloped is offline
TURBO-bb or j.b. what brand?
Noticed small amounts of side to side play in my turbo today, no in and out play, but side to side. So I'm starting to plan on an upgrade in the future.
My ? is,
There is some some compainies praising there non BB turbos, while I am awaire of the advantages to a BB turbo. Why are they saying to go with there non BB? Why does the Garret surge and TN not? What would you guys recomend to run with my stage 2 singles?
(don't ask why I did injectors before a turbo, that wasn't the plan untill I lost 3 injectors back in December.)
Old 07-11-2008, 05:40 PM
P.S. I do tow from time to time
Old 07-11-2008, 06:13 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
Originally Posted by siloped View Post
Noticed small amounts of side to side play in my turbo today, no in and out play, but side to side. It is normal for a little side to side. If it moves in and out, you have room for concern So I'm starting to plan on an upgrade in the future.
My ? is,
There is some some companies praising there non BB turbos, while I am aware of the advantages to a BB turbo. Why are they saying to go with there non BB? Why does the Garret surge and TN not?Who says the GT38R surges other than Joe? What would you guys recommend to run with my stage 2 singles?
(don't ask why I did injectors before a turbo, that wasn't the plan until I lost 3 injectors back in December.)
Above in red.
Old 07-11-2008, 06:54 PM
Wasn't sure about the side to side play being that bad. But I still want to upgrade anyway.
As far as the Garret, i searched earlier on the forum and read a thread ( and have heard this before) that the garret can surge when towing as where the TN hasn't
Old 07-11-2008, 07:07 PM
There are two options that are worth mentioning aside from the GT38R. The TN BB and the PDR super GTP. The PDR is rather new but has good reports so far. The TN BB is the hot ticket.
PDR Diesel Performance: * NEW * Super GTP Turbo - 1994.5-03 7.3L P/S
Black Widow Diesel
Old 07-11-2008, 07:27 PM
The only problem I have with this one is that it sayes its only rated to 400hp
Old 07-11-2008, 07:42 PM
Dusty's Diesel Dusty's Diesel is offline
look up high tech turbo Big bad wolf. This is a journal bearing turbo, adjustable wastegate. We put one on my buddy's 02. It really peforms well.
Old 07-11-2008, 07:51 PM
FYI, With your stage 2's, 400hp is all the fuel you have to work with.
Stay away from the big bad woof...... One just let go a couple of weeks ago on a truck. We took it apart and looked at the machining, what a POS. I would not put on my worst enemies truck. Of course HTT would not warranty it because it let go on a dyno. All it made with hybrids was 398hp.
Old 07-11-2008, 10:02 PM
Ross at dynomite said that with the stage 2 singles and a bigger turbo and proper tuning he expects it should be close to the 420 - 430 mark
Old 07-12-2008, 12:01 AM
Look up mikes7.3 on here. He runs DDP stage 2 injectors and runs a TN BB turbo with all the fuel system upgrades. He had his truck live tuned by Jody(DP tuner) and put down 402hp. Another 20-30hp from those injectors is going to be hard to get but I am sure it could be doable some how.
Your sig says 100hp injectors. I only find 75hp and 120hp injectors on the DDP website. Which ones do you have?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
