Go Back   Ford Powerstroke Diesel Forum > Ford Powerstroke 99-03 7.3L Forums > 99-03 7.3L Performance Parts
Old 07-11-2008, 05:26 PM
drtydzel drtydzel is offline
Send a message via Yahoo to drtydzel
HPOP dual or custom single
I am looking to upgrade my HPOP and injectors at the same time I want to go to a Stage III injector. Any idea on what HPOP to use whether a big single or dual set up not sure what way to go on this subject yet let me know what you all think.
Old 07-11-2008, 05:46 PM
CoalRollinRoosterCruiser CoalRollinRoosterCruiser is offline
Mighty Mouse
Send a message via AIM to CoalRollinRoosterCruiser
Couple of questions,
1. Why stage 3's?
2. Is your truck automatic. If so, you still got the stock 4r100
3. Do you still have the stock PMR rods that came in the 01 trucks?
Old 07-11-2008, 06:04 PM
I am currently over seas and doing my motor work them my trans work so my trans is currently stock but only till the motor is done. Yes my rods are currently stock as well but it will be getting rods and a main girdle, head studs, fire rings, etc.... why stage III's I'm not to worried about mileage I just want the power my end goal is going to be 1000 LBS TQ minimum
Old 07-11-2008, 06:07 PM
Mighty Mouse
Ahh, ok
Just makin sure all the supporting mods were going to be there.
I can't help ya in terms of whether to go single HPOP route, or dual's, but as for which company,
Stealth makes a good HPOP, and so does Terminator Engineering i believe.
Hope that helps
Hopefully someone more knowledgeable will be along shortly to help ya out
Old 07-11-2008, 06:09 PM
nic0084 nic0084 is offline
TEXAS STROKER
Stealth is popular round here.
Old 07-11-2008, 06:18 PM
strokin_early_99 strokin_early_99 is offline
John Wood Nut Swinger
With all that block work, why are you only thinking of stage 3's? Go with B codes, they start at 240cc which normal for stage 3 hybrids. Plus with stage 3's you don't need big oil.
What rods are you getting?
Old 07-11-2008, 07:32 PM
No you don't need big oil but a lot of the companies say they recommend it so i was just gonna roll with it. As far as rods I was looking at a set of hypermax from black widow. I normally order every thing threw black widow. I am open to all ideas and comments though. I will take all the help I can get.
Old 07-11-2008, 07:45 PM
Before you go and get the hypermax rods, make sure to tell them you are running 2 stages of giggle juice. They may recommend a set of crowers. Why are you look at a set of hybrids over a set of B codes? hybrids have a lower injection ratio than B codes meaning the B codes will atomize the fuel better. In addition, B codes have a lot of room to grow if you want more fuel later.
Old 07-11-2008, 07:52 PM
Kevin at black widow has a running tally of parts for my truck. So the crowler are a better choice to go with the bottle as well good to know thanks and well I will look into a set of B codes as well any recomendation on company and size for my power level I want like I said I will take all help i can get i am by no means a expert or a know it all and thats why I like forums like this one every one helps every one.
Old 07-12-2008, 08:54 AM
Deputydog Deputydog is offline
I have to vote for B codes as well.. They are about the same price as stage 3's but you can do much more with B codes in the future if you choose and don't have to buy another set of injectors.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
