Need some turbo advice/guidance - Ford Powerstroke Diesel Forum
post #1 of 4 Old 10-12-2013, 08:08 PM Thread Starter
LvGolfer962's Avatar
The turbo went out on my 2000 7.3 with 194k
I dont really need more than a stock turbo, but i do like the fact that the 38r is a ball bearing turbo.
So after a little reading and searching
If i get the 38r
theres a pedestal that deletes ebv
then you would need the turbo outlet that deletes the ebv
So what is the ebv? and is there anything else you have to do to complete the deleting of the ebv or are these all the parts?
And while all the turbo is out
is there anything i should be replacing that commonly fails or wears out?
Thanks in advance !
LvGolfer962 is offline
post #2 of 4 Old 10-12-2013, 09:23 PM
usteffenhagen's Avatar
With regards to the EBV...
The Exhaust Back Pressure Valve just aids the engine to warm up faster in colder weather. All it is is a valve that closes to create back pressure hence the name. There's really no gain with it. I haven't noticed it warm mine up any faster and it's just annoying to hear the hiss driving around. Pulled up a few links for you in case they might help Also it does leak oil and I think mine might be now that I think about it....
EBPV Removal
EBPV DELETE CHAT, need some help!
--Uriah--
2001 F350 XLT 7.3 PSD ECLB SRW automatic, 160,000(ish)
WIX 6637
4in. turbo back straight pipe 5in. tip
Zoodad
ATS turbo shroud
6pos TS chip
ISSPRO Gauges (EGT, Trans, Boost)
Foil delete
$.50 MOD
To come soon: EBPV delete, new steering gear box/ pump
usteffenhagen is offline
post #3 of 4 Old 10-12-2013, 09:24 PM
Oh and check your compressor wheel to make sure no fins are cracked, chipped or dusted. Might as well check your inter cooler boots too for oil leak
--Uriah--
WIX 6637
Zoodad
ATS turbo shroud
6pos TS chip
Foil delete
$.50 MOD
post #4 of 4 Old 10-13-2013, 08:41 AM
blue99stroker's Avatar
Quoted: 258 Post(s)
you can delete the stock pedestal and outlet and re use them.
or you can buy a New outlet and pedestal for around 180-200 bucks.
riffraff sells them
99.5 f250 7.3 4x4 261k FF 160/30, PHP Hydra, S&B CAI, 4" TBE, Van Turbo with Turbo Blanket, RR Billet Wheel, Autometer Gauges, Transgo Tugger, Non-Ebpv Pedestal, 08 Tow Mirrors, Trucool.
Dad-2000 F250 7.3 4x4 111k Autometer Gauges, Superchips 1705 (Tow Safe), 6637, 4" TBE, BD Billet Wheel, Trucool.
blue99stroker is offline
